Adjusting the Bonnet and the Bumper
pjsmetana
My Spitfire was restored about a year or so ago (according to the PO), and it wasn't perfect. The gap where the bonnet meets the doors has about a 1/4 of an inch difference and my front bumper (yes those silly big black ones) is sitting about a 1/2 an inch low on the front... Kinda like someone was sitting on it.
So how do I adjust these? I suppose it would be easier to do with a 2nd person around... and since my wife is a bit impatient, I would like to have some direction before I loosen a bunch of bolts and play with it.
Thanks guys/gals!
tdskip
It should just be a matter of loosening up the bolts and spending a bunch of time fiddling with the alignment. Sometimes shims are necessary. The last time I pulled and replaced a fender it was just a matter of spending lots of time, patience assisted by a beer, getting it right.
I'd get some other opinions from the guys here before tearing into it.
69tr
I had a similar problem on my TR6. If I remember correctly you can get to the bonnet bolts while it is closed if you can get the car off of the ground.
This is what I did with my '6. Removed the grill so I could get to the hood mounting bolts and removed the hood latch so I could move the hood and closed the hood. I then loosened all of the hood mounting bolts and moved the hood around until all of the seams were pretty close and tightened everything up. It took me a few tries before I got it to this point. I did this working alone and had no problems.
Don't know if this will work on the Spitfire.
Hope this helps, Pete
pjsmetana
pjsmetana
pjsmetana said:
... loosen a bunch of bolts and play with it...
tdskip said:
... loosening up the bolts and spending a bunch of time fiddling with the alignment...
69tr said:
... loosened all of the hood mounting bolts and moved the hood around...
Roger that... Loosen and Fiddle.
DNK
Hey Pete- ya just need to loosen and fiddle
NickMorgan
Yes, loosen and fiddle. However, the bonnet is very heavy and notoriously difficult to adjust. If it is like a Herald, there are two or three bolts on the front hinges alone. By adjusting them all, it is possible to raise or lower the bonnet and move it back and forth. You may be able to adjust the bonnet to get the gap right with the bumper. The gap between door and bonnet is always a little wide.
There was a good article in last month's Triumph World magazine about adjusting Herald bonnets.
B TR2/3/3A 57 TR3 BONNET ADJUSTING SHIMS Triumph 4
wangdango 100m bonnet fitting/adjusting?? Austin Healey 4
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
AUSMHLY Adjusting Valve Clearance Austin Healey 31
S Testing and Adjusting procedure for RB340 Austin Healey 4
doc50 Adjusting play on steering box? Other British Cars 5
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
BN6_2197 Rookie question on adjusting valve clearance Austin Healey 9
Jim_Gruber Adjusting Spridget Doors Spridgets 4
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
vette Adjusting HD8 Carbs Austin Healey 21
M Adjusting Front Suspension Austin Healey 11
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
B Adjusting SU-HD6 Carbs Austin Healey 2
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
S TR2/3/3A little adjusting screw tr3 Triumph 1
F Adjusting gear lever, centershift 3000 Austin Healey 2
L Adjusting the bows before top installation Austin Healey 2
bighealeysource Adjusting toe in on a Healey Austin Healey 8
M Adjusting TR3 regulator Restoration & Tools 1
Scotsman Adjusting clutch pedal travel Triumph 2
R Adjusting Valve Clearances Triumph 13
Moseso TR2/3/3A Adjusting Koni shocks [TR3] Triumph 10
N Adjusting headlights on a BJ8 Austin Healey 2
A Adjusting BJ8 Doors Austin Healey 5
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
drambuie Adjusting steering box with shims Austin Healey 6
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
M Adjusting idle speed Triumph 28
bighealeysource adjusting the handbrake on BN6 Austin Healey 1
TR6oldtimer Adjusting rockers Triumph 7
Darwin Adjusting steering play? Triumph 7
hondo402000 TR6 adjusting windows to Wind screen TR6 Triumph 2
T Adjusting valves makes me more crazy. Triumph 18
JohnnyMead Tips on Adjusting the Clutch Slave Pushrod? Triumph 4
pjsmetana Low Idle, DVG adjusting = no dice Triumph 12
DarwinT Adjusting a Weber carb Spridgets 3
bighealeysource ADJUSTING THE HAND BRAKE ON A BN1 Austin Healey 1
Y TR4/4A Adjusting valves on a TR-4 Triumph 4
