TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes
mastaphixa
Bronze
I've adjusted several Tr3a rear brakes before never had this problem. The passenger side behaves as expected as I adjust the shoes out into the drum encountering more resistance as the adjuster is wound in. The driers side goes from no resistance with the adjuster being wound in with the normal segmented clacks as the the shoes move out into the drum to being impossible to wind in any further and impossible to loosen either! Nothing gradual about it. I've ruined a couple of 5/16" wrenches in the process. I was able to beat the drum off the shoes (not happy about that!) and inspection of the adjuster components reveal's nothing unusual. Odd that it goes from no resistance to bound up in less than one segment of adjustment. Anyone else run into this?
Regards,
Steve Baker
trglory
Now that the drum is off and there is no pressure on the shoes, is the adjuster still seized? If so, you may have thread damage or you may be at the end of the adjusting screw travel. Take the shoes out and try to rotate the adjuster back in. Be aware that the body of the adjuster is aluminum so treat it gently. Also, get yourself a closed end square wrench (TRF has them) to avoid rounding the flats on the adjuster screw. This is the only thing you will ever need it for but the damage you inflict without it will cost a lot more than the wrench.
M
mastaphixa
Bronze
The adjuster is not seized. With the drum off it rotates smoothly and the wedges move in and out quite easily. I'm getting an 8pt socket to help with the tooling issue.
CJD
I would think that means the shoes have worn to a perfect match with the drum, and bonus, the drum is not warped at all. Just go to the notch before it locks and call it good.
trglory
Sounds like you are good to go. While you have everything apart put a dab of anti-seize compound on the adjuster threads.
M
mastaphixa
Bronze
The adjuster appears to operate normally when the brake drum is removed. Nothing is seized, the wedges (and brake shoes) move in and out accordingly when the adjuster is moved in or out. Once I install the drum and try to adjust the shoes I go directly from no resistance to locked and the adjuster is so tight I can't turn it in or out. Obviously I have something messed up and will report back when I figure it out.
trglory
I hear what you are saying. It has been my experience that a little anti-seize compound helps you dial in just the right amount of drag.The cam locks it in so that it won't move unless you turn it again.
M
mastaphixa
Bronze
My 8pt socket did the trick. Everything was assembled properly and I'm not sure why the left adjuster behaves so differently than any of the other adjusters I've encountered but I was able to get the brake adjusted. I can definitely see the merit of the above mentioned tool and will include it in my next Moss order.
Tr3aguy
Steve,
Mine on was side was frozen like someone had put thread locker on it. I had to take it apart and work it up and down a little at a time, It felt just like the threads were damaged but after runnning it up and down for a while without the spreaders in it was good. Put it back together with some anti seize compound
M
mastaphixa
Bronze
Mine had been completely disassembled, walnut shell blasted, and the threads have been chased. I added silicone brake grease to the interface between the wedges and the adjuster. There just isn't much room for adjustment between no drag and locked. I'm happy with it for now. I need to get a few miles on it and revisit it. That will be out there in the future. I appreciate all the feed back!
Steve Baker
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
SherpaPilot TR6 Difficulty with New Seat Diaphragm Install Triumph 6
S Difficulty removing end rods and cross rods Austin Healey 11
M TR4/4A Difficulty communicating with TRF in USA Triumph 12
R difficulty shifting/downshifting-BJ-7 Austin Healey 7
T Difficulty starting engine Triumph 31
rlandrum TR2/3/3A TR3A Lower Wishbone Installation Difficulty Triumph 5
amcboy Post-War Other Difficulty in converting Volvo 1800 J-type O/D? Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
AUSMHLY Adjusting Valve Clearance Austin Healey 31
S Testing and Adjusting procedure for RB340 Austin Healey 4
doc50 Adjusting play on steering box? Other British Cars 5
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
BN6_2197 Rookie question on adjusting valve clearance Austin Healey 9
Jim_Gruber Adjusting Spridget Doors Spridgets 4
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
vette Adjusting HD8 Carbs Austin Healey 21
M Adjusting Front Suspension Austin Healey 11
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
B Adjusting SU-HD6 Carbs Austin Healey 2
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
S TR2/3/3A little adjusting screw tr3 Triumph 1
F Adjusting gear lever, centershift 3000 Austin Healey 2
L Adjusting the bows before top installation Austin Healey 2
bighealeysource Adjusting toe in on a Healey Austin Healey 8
M Adjusting TR3 regulator Restoration & Tools 1
Scotsman Adjusting clutch pedal travel Triumph 2
R Adjusting Valve Clearances Triumph 13
Moseso TR2/3/3A Adjusting Koni shocks [TR3] Triumph 10
N Adjusting headlights on a BJ8 Austin Healey 2
A Adjusting BJ8 Doors Austin Healey 5
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
B TR2/3/3A 57 TR3 BONNET ADJUSTING SHIMS Triumph 4
drambuie Adjusting steering box with shims Austin Healey 6
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
M Adjusting idle speed Triumph 28
