TR6 Difficulty with New Seat Diaphragm Install
SherpaPilot
Rather than replace my seats with aftermarkets, I made the decision to recover both seats in my 72 TR6. I'm now into the initial phase but having a very difficult time installing new diaphragms. I know other forum members had similar problems but i could not locate previous posts on the subject. I ordered these items from Moss. They seem well made and heavy duty. Thus far, I was successful in attaching the item from the rear frame as well as the sides. in spite of this, I am still a good 2 inches short from the front frame and unable to stretch this thing that far. I was considering heating the rubber with a heat gun and winching it into place using a come-a-long but was afraid i would destroy it and end up at square 1 again. I have contacted Moss and requested confirmation on the part number 281-838 as being the correct replacement part but have not heard anything back yet.
My question is: Should this installation process be this difficult? Has anyone who rebuilt their stock seats have a technique to stretch this rubber to fit the frame? My frames are in excellent shape and totally stock with no alteration or damage. I'm using heavy duty vise-grip needle nose pliers to pull the hooks into place. As usual, any friendly advice will be appreciated. Thanks in advance.
Madflyer
I do not remember a problem with mine but I do not buy from Moss, two many problems with there parts. I did do an MG B last year and I had to add longer hook as as there was to much pull required. I do not think it should be very tight as you will do that when you set down. Madflyer
charleyf
I have done 3 TR6 seat sets with parts from TRF and had no problems.
SherpaPilot
SherpaPilot
I was finally successful in installing this. My problem was self-induced because I was attaching the hog rings from the bottom up. By the next day, it finally dawned on me that the hooks need to be installed from the top. That way the sharp edges will be facing downward. This is my first seat and I'm learning as I go along. The remaining seat will be easier. Thanks for the responses.
Andy Blackley
I recently did this job, also using diaphrams from TRF. I did the front to back ones first which were easy and for the sides I had my son hold down the frame while I pulled on the hog ring using a stout, looped cable tie. Went pretty quick.
SherpaPilot
SherpaPilot
Good idea with the cable tie. Thanks for your advice. I'll be a happy camper to get this job completed.
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
S Difficulty removing end rods and cross rods Austin Healey 11
M TR4/4A Difficulty communicating with TRF in USA Triumph 12
R difficulty shifting/downshifting-BJ-7 Austin Healey 7
T Difficulty starting engine Triumph 31
rlandrum TR2/3/3A TR3A Lower Wishbone Installation Difficulty Triumph 5
amcboy Post-War Other Difficulty in converting Volvo 1800 J-type O/D? Triumph 6
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
C Seat Slide Bearings Austin Healey 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
