TR6 Extreme difficulty in shifting into Reverse?
CJD
Most of the time it would be a dragging clutch...if it grinds when going into reverse. If there is no grinding, and it just feels like you're hitting a stop, then the teeth are worn/chipped.
K
karls59tr
Bronze
I know on my TR3 (with TR6 gearbox when I fit the 3/4" piece of rubber hose on the stick shift ,as others have done to prevent gear shift rattle, it was very hard to get the shifter in reverse. I'm thinking maybe the PO did that mod and that's the issue? Can the gaiter and rubber boot type grommets be removed without removing the carpet on the gearbox on a TR6?
K
karls59tr
Bronze
It eventually goes into gear and does not stop just a great deal of effort to do that. Shifts fine thru all the other gears.
K TR2/3/3A Headlights and their extreme current draw? Triumph 4
TRclassic3 TR2/3/3A Extreme tire wear Triumph 6
Morris Extreme Frustration Spridgets 15
R6MGS Extreme Degreasing! Restoration & Tools 16
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
SherpaPilot TR6 Difficulty with New Seat Diaphragm Install Triumph 6
S Difficulty removing end rods and cross rods Austin Healey 11
M TR4/4A Difficulty communicating with TRF in USA Triumph 12
R difficulty shifting/downshifting-BJ-7 Austin Healey 7
T Difficulty starting engine Triumph 31
rlandrum TR2/3/3A TR3A Lower Wishbone Installation Difficulty Triumph 5
amcboy Post-War Other Difficulty in converting Volvo 1800 J-type O/D? Triumph 6
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
AUSMHLY BJ8 Gear Shifting Austin Healey 5
L TR2/3/3A Shifting problems Triumph 4
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
M Grinding when shifting into first Spridgets 10
S TR2/3/3A shifting tower shifting rods on an early tr3 tower Triumph 11
S TR2/3/3A drilling out shifting tower for a dip stick Triumph 10
1 MGB 1966 MGB hard shifting into 3rd MG 1
Jim_Gruber Clunk in the rear when shifting Spridgets 26
K TR2/3/3A Shifting back from Reverse to First... Triumph 3
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
C Shifting problem? Triumph 15
F Missing pieces- centershift 3000- vague shifting Austin Healey 4
J Difficult Shifting Triumph 8
britndablood Side shift tranny with shifting issues Austin Healey 10
longbridgehealey gears grinding when shifting Spridgets 11
J TR4/4A Hard Shifting TR4 Triumph 2
B Down shifting problems, check my thinking? MG 1
P Shifting a J2 MG 9
stretchit2 Side Shifting Tri Carp Austin Healey 14
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
jaegzie Close Tranny shifting pattern Spridgets 0
R 1500 gearbox, trouble shifting into first from neu Spridgets 20
thechileman TR4/4A TR4 Shifting problem Triumph 3
R trouble shifting, getting into gear &stuck in gear Spridgets 22
I TR6 tr6 shifting problems Triumph 12
eschneider T-Series Clutch - shifting problems - help? MG 19
Bruce_B Shifting Triumph 3
Jayrz Poor Shifting 2nd gear MG 5
K TR6 73 tr6 tranny shifting Triumph 1
M Shifting Issue: Clutch Question Spridgets 4
