Jim_Gruber
Put Bugsy back up on jack stands tonight to fix a few things. Clunk in the rear end when shifting. Tranny bolts seem tight, driveshaft is tight, other than a bad universal WTH else is there that would cause a loud and very much felt clunk in the driveline. Everything feels tight. Will grease U Joint see if that helps.
Coolant dripping underneath. Crap heater valve leaking at the base. Found a spare gasket in the garage. Something else to fix and then on to the brakes.
