TR6 TR6 passenger side rear rattle/clunk?
mabbott
Member
My TR6 has a rattle/clunk noise in the area of the passenger side rear. It sounds like the exhaust hitting the frame but when parked I shake the exhaust and it doesn't rattle/clunk.
Any ideas?
T
Tinster
The easiest item to check is the shock mounting
bolts. Sometimes they back out and produce a
clunking sound over bumps.
Next in line is the dreaded passenger side front
Differential mount box.
d
jackag91
Sounds like you are going to need to put it up on stands. Hopefully it will just be something loose...the next best thing you can hope for is the bushings need to be replaced, then it is the ujoints, then the diff mount box.
If you put it on stands and have a buddy of yours jerk the wheel, you should be able to figure it out.
Read this
https://www.vtr.org/maintain/diff-mounts.shtml
mabbott
mabbott
Member
It only happens when going over bumps....even small bumps. Doesn't occur when shifting or on hard power.
I will put it up on stands and check out the possibilities mentioned.
Thanks
T
Tinster
Mabbot-
Before you put the car on stands, have someone
push the passenger's rear corner down while you
have your head near the wheel and listen for the
general direction of the clunk.
Here is a decent pictorial of the various rear
end components that might clunk.( broken diff
mount not shown)
https://www.scribd.com/doc/92509/TrailingArmBushingsFinal
Hope this helps you find and fix your clunk
ScottTR6
Dale, excellent job on the documentation. You are the best, this will be invaluable for my future clunks.
Thanks,
Andrew
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Dale, excellent job on the documentation. You are the best, [/QUOTE]
Dale T, Crypt Car Technician, Extraordinare!!!!
Only 12 short months ago, he was merely a mild mannered architect living happily with his lovely wife on an island paradise and then the red she-devil limped into his life.
The rest, as they say, is now history..........
T
Tinster
Yupper Paul,
I have the best looking, most parts removed and replaced,
non-functional, TR6 on blocks in the entire Caribbean.
I sure have become an expert in the field of
jack stand ,non-running TR6s.
Since I had to gut out the PDO Pedro's fuel tank to
refurbish it for the 100% replacement of the non-functional
fuel delivery system, I just had to add a Tinster touch to
the tank. Wait until you see it! Bold it is!
Photos to follow, hopefully next week.
PS: Since my TR6 is NOT a show car, and it's certainly NOT
even close to being a daily driver; I can make just about
any modification I want and who cares but my cat Noel who
enjoys sleeping on the passenger seat.
d
kodanja
So what yer telling us is "your car is a CAT HOUSE"
dndkk
Member
Excellent article.... thanks for taking the time to detail.....
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
T TR6 Passenger side TR6 rear clunk? Triumph 9
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
A TR6 '73 tr6 passenger front brake dragging Triumph 2
N TR6 TR6 Passenger door and window fit ? Triumph 5
Got_All_4 TR6 1969 Triumph TR6 passenger seat Triumph 13
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
