TR6 '73 tr6 passenger front brake dragging
achtungeveryone
I replaced the brake master cylinder and bleed with mityvac hand held unit. driving the car, I could tell rolling in neutral was hindered. I then jacked up each wheel and spun...found the passenger front only turns with lots of effort so it seems the brake is not fully engaged on the rotor but enough to effect it significantly. I wasn't impressed with the quality of bleed I got out of the mityvac but not sure if air in the system would cause one of the calipers to engage. I know there is a switch in the front system that can get wonky when doing hydraulic work but the brake light isn't on when the car is running. any ideas?
thanks, Chris
trrdster2000
You have a stuck piston. Several causes, it got cocked or rust is keeping it from moving properly. Try to push in both pistons and pump them back out a couple of times. If that doesn't work, you will need to pull them out and check for rust and replace the rubber seals in any case. Don't take the two halves apart unless you have replacement proper "O" ring. It's a little wider than your typical seal.
Wayne
M_Pied_Lourd
It's also possible that your flexible lines need to be replaces. Often they can look ok on the outside but can collapse on the inside.
Cheers
Tush
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
T TR6 Passenger side TR6 rear clunk? Triumph 9
N TR6 TR6 Passenger door and window fit ? Triumph 5
mabbott TR6 TR6 passenger side rear rattle/clunk? Triumph 11
Got_All_4 TR6 1969 Triumph TR6 passenger seat Triumph 13
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
