TR6 Passenger side TR6 rear clunk?
tdskip
Yeah, but I don't believe it is the usual differential mount as I reinforced them and it happens on bumps not on power take up.
It is only on vertical motion, side to side doesn't make it happen. I can make it clunk a bit by rocking the car up and down at a standstill.
Any ideas? Body mounts maybe?
I'd like to think I tightened the trailing arms properly, and she does have 600+ miles on her like this without anything bad happening or her handling being impacted.
hondo402000
if you have the original lever shocks check to see if the mounting bolts are tight, use a torque wrench to make sure you get them set correctly, if you have one
Hondo
sail
Drive you crazy. I have one I can't find but ever since I took the head off it hasn't been a problem. Agree shocks can make a racket with either the bolts or the attachment to the TA slightly loose.
YYCDave
Hondo
And in addition check the shock links and bushings where they attach to the TA.
BobbyD
Your axle splines may be dry and that will make a clunk-like sound under the right conditions.
And as mentioned......... the stock shock mount
T
tdskip
Found it - one of the shock mounts bolts has worked it way loose. Not sure how the heck that happened - I must not have tightened it properly. Yikes!
Thanks guys.
TR3driver
Great Pumpkin - R.I.P
I was forever having that problem on my TR3/A, until I substituted Stover nuts for the Nylocs. I also ground down a flat washer so it would fit under the nut and help keep the shock ear from getting chewed up; plus go for 30-35 ftlb (higher than the factory spec of 26-28).
https://www.mcmaster.com/#3199
(I use the "conical-top" version but the others would probably work just as well.)
T
tdskip
Ah, didn't know they had a tendency to do that. I just assumed I screwed up (may have still).
Thanks for the ideas on how to address.
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
mabbott TR6 TR6 passenger side rear rattle/clunk? Triumph 11
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
K TR2/3/3A Passenger side fender mirror....... Triumph 13
Jim_Stevens TR2/3/3A Firewall passenger side Triumph 2
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
D Poor fit door and glas to top on passenger side. Austin Healey 7
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
D Spitfire WTB window regulator, passenger side, '65 Spitfire Triumph 3
T Wedge TR8 scraping noise from the passenger side rear Triumph 10
I Need tracing for passenger side 69-72 kidney pad Triumph 7
MadRiver New Clunking Noise from the Passenger Side Triumph 2
TNMGB Rattle on rear passenger side MG 17
M USELESS PASSENGER SIDE BULLIT MIRROR FIX Triumph 21
msoylemez wiring harness on passenger side Spridgets 5
Musicman Installing Passenger Side Mirror Triumph 7
J Passenger side water leak MG 3
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
charlie74 Wanted Passenger seat replacement foam [‘74] Triumph Classifieds 0
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
S TR2/3/3A passenger door Triumph 24
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
B Wanted TR250 passenger seat Triumph Classifieds 0
A TR6 '73 tr6 passenger front brake dragging Triumph 2
Jim_Gruber BE Passenger seat bases Spridgets 6
B Passenger interior door handle issue [1960 BT-7] Austin Healey 4
richberman Longbridge passenger lock chrome lever anyone? Austin Healey 8
Tr3aguy TR2/3/3A Looking for a passenger door!!! TR3 Triumph 20
Boink Passenger Parcel Shelf in a Bugeye Spridgets 25
H Tailpipe exhaust back into passenger compartment Austin Healey 26
brgrmyster GT6 GT6 Mk 1 Passenger Foot Rest? Triumph 3
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
Tinkerman TR2/3/3A TR 3A Passenger Seat Tilt Forward Bolts Triumph 3
J BJ8 passenger foot well [LHD], right wall Austin Healey 1
S MGB Removing the passenger seat from my 71 MGB..... MG 4
T Wedge TR8 passenger floor - advice needed Triumph 7
Number_6 TR2/3/3A TR3A Passenger door Triumph 11
N TR6 TR6 Passenger door and window fit ? Triumph 5
regularman Is there room under the passenger seat.... Spridgets 11
X Sagging passenger door MG 14
Got_All_4 TR6 1969 Triumph TR6 passenger seat Triumph 13
B Passenger seat is derusted and primed!! Spridgets 3
M 87 XJ6 Driver and Passenger Footwell Water Leaks Jaguar 2
