BE Passenger seat bases
Jim_Gruber
Trying to pull passenger seats out of my 59 BE parts car Bugsy III. Are the nuts holding to seat frame to to 4 mounting brackets captive. Unsure how I unbolt to get the frames out. Best method for removal. Seat bases and frames look great. Car was reupholstered circa early 70's and bases got a good coat of red rustpreventerat that time.
59diamond
I certainly wouldn't know the answer to that. Heck I just discovered from another post that my front bumper is on upside down.
But HAPPY EASTER anyway.
JPSmit
Jim assuming they ar the same as later cars, they are captive nuts. Should be an easy removal. Slide seat sll the way back for front two bolts and all the way front wards for back two bolts.
Jim_Gruber
Jim_Gruber
Charlie I can feel nuts underneath that the seat frame is fastened but it appears nuts visible from top have been ground off.
Coastalman
I'll go tomorrow to the garage and check, but I believe that there is just a hole in the floorboard that you can look through and see the captured nut right up against the floor. Unless I am missing something, there are no nuts on top.
Rut
Jim,
just looked at my old floors at the 2 nuts on the tunnel side are welded to the under floor 'stiffener'. The sill side of my floors were in bad shape and just had holes. The replacement floors have nuts welded on the bottom rear only with holes in the front.
Rut
charlie74 Wanted Passenger seat replacement foam [‘74] Triumph Classifieds 0
B Wanted TR250 passenger seat Triumph Classifieds 0
Tinkerman TR2/3/3A TR 3A Passenger Seat Tilt Forward Bolts Triumph 3
S MGB Removing the passenger seat from my 71 MGB..... MG 4
regularman Is there room under the passenger seat.... Spridgets 11
Got_All_4 TR6 1969 Triumph TR6 passenger seat Triumph 13
B Passenger seat is derusted and primed!! Spridgets 3
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
K TR2/3/3A Passenger side fender mirror....... Triumph 13
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
Jim_Stevens TR2/3/3A Firewall passenger side Triumph 2
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
S TR2/3/3A passenger door Triumph 24
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
A TR6 '73 tr6 passenger front brake dragging Triumph 2
B Passenger interior door handle issue [1960 BT-7] Austin Healey 4
richberman Longbridge passenger lock chrome lever anyone? Austin Healey 8
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
D Poor fit door and glas to top on passenger side. Austin Healey 7
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
T TR6 Passenger side TR6 rear clunk? Triumph 9
D Spitfire WTB window regulator, passenger side, '65 Spitfire Triumph 3
Tr3aguy TR2/3/3A Looking for a passenger door!!! TR3 Triumph 20
Boink Passenger Parcel Shelf in a Bugeye Spridgets 25
H Tailpipe exhaust back into passenger compartment Austin Healey 26
brgrmyster GT6 GT6 Mk 1 Passenger Foot Rest? Triumph 3
T Wedge TR8 scraping noise from the passenger side rear Triumph 10
I Need tracing for passenger side 69-72 kidney pad Triumph 7
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
MadRiver New Clunking Noise from the Passenger Side Triumph 2
J BJ8 passenger foot well [LHD], right wall Austin Healey 1
T Wedge TR8 passenger floor - advice needed Triumph 7
Number_6 TR2/3/3A TR3A Passenger door Triumph 11
N TR6 TR6 Passenger door and window fit ? Triumph 5
TNMGB Rattle on rear passenger side MG 17
X Sagging passenger door MG 14
mabbott TR6 TR6 passenger side rear rattle/clunk? Triumph 11
M 87 XJ6 Driver and Passenger Footwell Water Leaks Jaguar 2
M USELESS PASSENGER SIDE BULLIT MIRROR FIX Triumph 21
msoylemez wiring harness on passenger side Spridgets 5
Musicman Installing Passenger Side Mirror Triumph 7
Johnny Occasional passenger, for the occasional 4 seater Austin Healey 4
