Wedge TR8 scraping noise from the passenger side rear
tdskip
Hi guys - after several years of faithful service on fast road rally events the TR8 has developed a scraping noise from the passenger side rear axle area. It is rotation based, but is not the wheel bearing. It will stop making the noise in neutral, comes back when power is transferred. Her differential has the right oil level in her and the right type of oil.
The noise requires the drive train to be engaged, if you put the clutch in it goes away.
The noise is louder in 2nd gear than 3rd or 4th. The noise is coming from behind the seats / rear of the car, I would have expected gearbox noise to be under the front/middle section. But odd that 2nd gear is so much louder. A diff wouldn't wear in just one gear, would it?
Any ideas?
Thanks
Gliderman8
Universals?
T
tdskip
Hi Elliot. Would a u-joint be more/less noisy in a given gear?
How is your 6 BTW, just driving her or any projects?
DNK
U joints seem to be noisier under power .IIRC?
T
tdskip
Hi Don, agree but why louder in 2nd gear rather than 3rd then? Wouldn't for same power the joint make same noise?
tr8todd
Stock TR8 driveshafts don't have universals. Any chance the shifter quadrant is rubbing on the driveshaft? Is it possible that the rear backing plates are rubbing against the drums? How about e-brake cable rubbing on the driveshaft? Take a look at the driveshaft first and see if there is an area where the paint has rubbed away.
DNK
Dang, Forgot that as I replaced mine long ago
T
tdskip
OK guys - spend some more time driving and I got the initial description wrong. It is from the rear center. Present in all gears, more so when accelerating, not just 2nd.
Pretty sure it is the differential at this point.
T
tdskip
Hi Randy - I'm 99% sure it is the differential. Sorry.
Guys - are we thinking most likely UKC978?
cheseroo
I don't think you are going to know until it comes apart. I would think the ones at the end of the spider gears could be culprits as well.
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge TR8 starter solenoid details? Triumph 3
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
S Wedge TR8 Starter wiring help needed Triumph 18
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
Mickey Richaud General TR TR8 Folks Triumph 0
T Wedge TR8 parts car Triumph 3
philman Wedge Tr8 on local craigs list Triumph 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
Darrell_Walker Wedge Rimmer's front rally spoiler installed on my TR8 Triumph 22
JFS Wedge TR8 Hazard Flasher Triumph 15
aeronca65t TR7 / TR8 on Garden State Parkway - NJ Spotted 0
