Rattle on rear passenger side
TNMGB
So I am happily zipping along today and all was well until I suddenly noticed a pronounced rattle around what appears to be the rear passenger side. I got home and checked to make certain that everything that could be tightened was (trunk lid and fittings, chrome trim, etc.). I drove around the block and there is still quite a rattle that was never there before. Any suggestions before I go see "The Man"? I just don't want something major to fall off as I'm driving out to see about having him look at it...
Thanks!
Steve_S
Inside out outside? Can you feel it rattling or just hear it? High pitched rattle or low pitched clunk? the more descriptive the better as there are a million things that can rattle on a car.
RickB
Check for missing rubber bumpers on the trunk.
I had an aggravating rattle that seemed to come from the dash turned out to be a rubber bumper/buffer that broke & went missing up front in the channel where the hood closes.
It's funny the way sound travels.
Here's how I found what was causing the rattle.
I have an orbital buffer, (wax on - wax off). I turned it on & buffed the heck out of the hood area until I heard the same rattle - this told me where to look. Opened the hood & right there was (er.. wasn't) the missing rubber bumper. I used a piece of foam rubber until a new set arrived.
Of course, like Steve said - it could be 999,999 other things. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
TNMGB
TNMGB
It seems to be coming from the inside as best I can tell...I think. I really just hear it and don't feel it. It sounded as though it could have been the luggage rack so I tightened that as well as the lock on the trunk but the rattle was still there. The rubber bumper idea sounds good so I will really scope things out as best I can and see what the deal is. I would really classify it as a mid-range rattle, not too high nor low. I just worry that it could be leaf spring issues or something along that line...I worry a lot!
Thanks!
Platinum
VERTICAL SHOCK LINK!
Check the "ball" end at the spring. Grab it (the link) and "shake vigorously".
Platinum
You're thinkin' exhaust, Steve? I just made the assumption it was when under way.
Silly me. /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
jlaird
How about a shock mounting bolt. Don't ask why I say this.
Platinum
Steve_S said:
Among other things, yes. It could even be something in the boot.
I thought that as well: errant lug wrench, loose wheel hold-down... an amazing list of "possibles". /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Platinum
If that's the case there will be a "witness" mark of some description around the edge where the shock body comes in contact with the chassis... a kind of "clean" outline of the shock body edges on the panel it's bolted against.
...seen that too.
Guinn
Also, if it rattles at low speed, can someone drive while you walk or trot alongside and listen?
Guinn
TNMGB
TNMGB
The culprit turned out to be the battery compartment cover. Like a goob, I had not screwed it back in after having trickle charged the battery overnight; I'd only laid the carpet back on top of the cover. I will say that it was good to check body fittings, luggage rack, etc. because several screws and bolts needed to be tightened down. That's a good preventative measure I will do on everything else, now that it's crossed my mind.
Thanks for all the suggestions!
Platinum
/bcforum/images/%%GRAEMLIN_URL%%/lol.gif
Good! Glad ya found it before takin' half the car into pieces! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
PAUL161
Not saying that's it but, that would be the first thing I'd look at too Doc!
jlaird
Was chating with my raceing bud yesterday and he said the race car will be back with suspension changes, paint, and a new engine the end of March.
Now to get to what TNMGB said. I told him I wanted two days to check evey fastner and every part before we put it on the track. Others work just scares me to death when I found suspension Nuts left off and nuts not safety wired, etc etc last year when I started takeing care of it.
However, that said I have no intention of doing the grunt work. Prep is fine, track side maintance fine. But yearly rebuilds, noop not me.
The point being, when was the last time you checked all the suspension bolts and nuts?
martyc
And I was gonna suggest checking that the vapor seperator in the trunk was not loose and rattling around. Little too late, but that was the source of one of my rattles! Glad you found it!
mabbott TR6 TR6 passenger side rear rattle/clunk? Triumph 11
T TR2/3/3A Rear shocks and rattle Triumph 5
Jer rear suspension rattle/squeak/clunk remedy... Spridgets 20
R Fender Spear Potential Rattle Austin Healey 6
K TR2/3/3A Timing chain rattle on start up? Triumph 2
M MGA MGA Engine Rattle MG 10
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
BoyRacer Rattle can Healey Blue paint Austin Healey 2
KVH Rattle Can Problems Restoration & Tools 5
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
C BN1 Clutch Pedal Rattle Austin Healey 2
B MGB-GT Need help with MGB GT rattle MG 0
S TR2/3/3A Rattle Triumph 9
S TR2/3/3A some rattle can primmer Triumph 9
warwick-steve Mystery Rattle Austin Healey 21
S TR2/3/3A Hood - Rattle Triumph 15
R TR2/3/3A Clutch rattle/clack-!957 TR-3 Triumph 10
S Colorado Red - is there a close approximation in rattle can? Austin Healey 4
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
Joe Reed MGB Rattle under front end? MG 8
PatGalvin TR2/3/3A Bonnet Prop Rod Rattle Triumph 20
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
vette A Rattle, no no it can't be. Austin Healey 8
B Door rattle Austin Healey 0
RJS TR4/4A Hood/Bonnet Prop Rod Rattle Triumph 10
D XJ6 series III front end rattle Jaguar 5
D Rattle in the boot Spridgets 7
RickB "Finished" my rattle can paint job Spridgets 19
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
AUSMHLY Does your window rattle when in the down position? Austin Healey 3
R Rattle that won't go away Spridgets 6
memphis Door Rattle Austin Healey 3
tri_carb_healey 3000, starter rattle? Austin Healey 14
RickB Rattle can advice please Spridgets 76
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
AngliaGT MGB-GT GT Shifter Rattle MG 4
cdsmith brake shoe rattle? Spridgets 10
jerrybny Anti-Rattle Spring and Plunger Triumph 4
jerrybny Anti-Rattle Spring Triumph 1
jerrybny Dreaded Stick Shift Rattle Triumph 2
Moseso TR2/3/3A TR3 Bonnet Rattle Triumph 24
zimmy anti rattle spring and plunger Spridgets 21
I TR6 TR6 Shake, Rattle and Roll Triumph 18
CCURTISS T-Series MGTF Shifter Rattle??? MG 4
tosoutherncars Rattle on startup - 1500 Triumph 5
B TR6 TR6 Disc Brake rattle Triumph 2
