anti rattle spring and plunger
zimmy
what exactly do they do,
and could this cause my gearbox to stick
in neutral?
after investigating mine appears to be
totally missing other than the nut
on the outside of the shift area....
im also not seeing a ring, bush, and spring
under my shifter knob....does my 1275 need
these?
dont remember seeing any of the above the
first time i took the gearbox apart.....z
jlaird
Oh me, you missing a handfull of goodies.
Give Tony a call he just may be able to help you out. Look on page 57 of the Moss catalog. Like items 57,58,59,60,61. All for less than 12 bucks.
Or someone here that has a real junker that is being parted out.
jlaird
Gota have it Zimmy. Like the good book says anti rattle and of course the peices at the bottom of the ball keep the shifter on track. No wonder it sticks in neutral.
Luke_Healey
I've been told that if you remove the stickshift to replace these parts, there is a chance they will fall down into the transmission, requiring a complete disassembly.
Is this a legitimate concern?
If not, I'd like to replace my bushing, since mine rattles like the devil.
jlaird
It can happen, just be careful and all will be well. I have no idea how many times I have had mine out and in without difficulitys.
jlaird
Not sure never haveing the problem.
2091351
And don't forget a Brand Spanking New 2A3339 to make sure it shifts like new.
Steve
jlaird
And that could be true as well. Zimmy did not comment on the hold down plate serviceability. A nice sole on the list here made me a new one, mine was trashed after 48 years. However, I should think someone would have one that could be used.
bugimike
Steve
Ok, I'll bite...where do you get a Brand Spanking new 2A3339? (It is an unlisted part in both Moss and VB cats.!!)
zimmy
zimmy
turns out, all im missing is the anti rattle spring and plunger....
the other stuff is down in the hole of the shifter where it goes.
anybody have and extra spring and plunger?
i hate to play $8 shipping on it if i
order it......z
jlaird
Now we moveing on.
tony barnhill
Great Pumpkin - R.I.P
Jack - page 57 of the Spridget catalog is about bumpers?
jlaird
Ahh, how about 28. Woops.
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
jerrybny Anti-Rattle Spring and Plunger Triumph 4
jerrybny Anti-Rattle Spring Triumph 1
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
I Bugeye anti-rattle plunger questions Spridgets 6
B Wedge TR8 front brake anti-rattle clips Triumph 1
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
T Need an Anti-Tramp Bar? Austin Healey 6
S TR6 Anti Run-On Valve question. Triumph 4
FlyingCat Spitfire Anti-Roll Bar Triumph 6
Bob_Spidell Healey Anti-Theft Device Austin Healey 0
steveg Anti-run on solution Austin Healey 10
JimLaney Anti-seize or Thread locker ? Spridgets 2
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
J Healey BJ8 anti roll bar bushes Austin Healey 2
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
B Anti-sway bar for a earlier BJ7 Austin Healey 3
bugedd Front anti roll bar Spridgets 11
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
tomshobby Have you checked your anti-freeze? Spridgets 1
tahoe healey disc brake anti squel pads Austin Healey 5
D TR6 Anti run-on valve Triumph 3
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
S Spitfire Question on anti run on valve 73 spitfire Triumph 5
Ed_K Installing new anti-sway arm bushings Austin Healey 3
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
H Anti run on valve MG 6
J Anti corrosion strips - Worth it? Austin Healey 8
ecurie_ecosse T-Series Anti run on switch. MG 11
G Anti-sway bar question Spridgets 1
HAN8L1965 CounterAct electronic anti rust system? Spridgets 22
Got_All_4 TR5/TR250 ADCO Anti sway bar installation on the Tr250 Triumph 4
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
Hairyone Anti-roll bar Spridgets 13
M Teves Anti-Lock Brakes, All Models up to year 1992 Jaguar 4
tahoe healey Anti-freeze Austin Healey 10
2wrench Pics showing repair to anti-run-on valve. Triumph 1
bigjones Sway bar [anti-roll bar] question Spridgets 8
