Anti-seize or Thread locker ?
JimLaney
I thought this is the kind of question that should be part of the "Restoration" forum but when I have posted there I have been told to post in our Spridget Forum so here goes:
I'm starting to work on the engine (1098) and transmission and want to know if there is a "rule of thumb" concerning which bolts and/or nuts should one use a thread locker and which an anti-seize product? I understand that bolts you imagine you will be removing in the future may need some anti-seize and those you want to be more sure will not work their way out might need thread locker but... any guidance on this subject?
dklawson
No Loctite on any rod, main, head or similar fasteners. You can lube them with oil or assembly lube but read up on how to adjust the torque when lubricant is on the threads.
Loctite sparingly on things like pan bolts, timing chain covers, etc.
Anti-Seize on things that get wet... like thermostat housing studs.
JimLaney
JimLaney
Thanks Doug!
bash Thread lock vs Anti-seize Restoration & Tools 8
C Loctite or Anti-seize? Triumph 11
A anti-seize recommendations for Radiator Drain Tap Austin Healey 10
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
T Need an Anti-Tramp Bar? Austin Healey 6
S TR6 Anti Run-On Valve question. Triumph 4
FlyingCat Spitfire Anti-Roll Bar Triumph 6
Bob_Spidell Healey Anti-Theft Device Austin Healey 0
steveg Anti-run on solution Austin Healey 10
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
J Healey BJ8 anti roll bar bushes Austin Healey 2
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
B Anti-sway bar for a earlier BJ7 Austin Healey 3
bugedd Front anti roll bar Spridgets 11
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
tomshobby Have you checked your anti-freeze? Spridgets 1
tahoe healey disc brake anti squel pads Austin Healey 5
D TR6 Anti run-on valve Triumph 3
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
S Spitfire Question on anti run on valve 73 spitfire Triumph 5
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
Ed_K Installing new anti-sway arm bushings Austin Healey 3
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
H Anti run on valve MG 6
J Anti corrosion strips - Worth it? Austin Healey 8
ecurie_ecosse T-Series Anti run on switch. MG 11
G Anti-sway bar question Spridgets 1
HAN8L1965 CounterAct electronic anti rust system? Spridgets 22
Got_All_4 TR5/TR250 ADCO Anti sway bar installation on the Tr250 Triumph 4
jerrybny Anti-Rattle Spring and Plunger Triumph 4
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
jerrybny Anti-Rattle Spring Triumph 1
Hairyone Anti-roll bar Spridgets 13
M Teves Anti-Lock Brakes, All Models up to year 1992 Jaguar 4
tahoe healey Anti-freeze Austin Healey 10
2wrench Pics showing repair to anti-run-on valve. Triumph 1
