Spitfire Question on anti run on valve 73 spitfire
ScottFromNH
Hey guys,
I have a question about the anti run on valve in the spitfires. I have a 1973 that I am redoing. Today while replacing the exhaust manifold I noticed I had to wires that were cut off half way down the firewall. After doing a lot of looking around I think I found where they use to attach to. I think someone cut the wires to the Anti Run on valve and trying to figure out why someone would do that? what does this valve do and should I be hooking the wires back up?
Scott
TR3driver
Great Pumpkin - R.I.P
The valve only makes a difference right after you turn the key off. What it does is apply manifold vacuum to the carb float bowls, stopping the flow of fuel into the engine and hence ensuring that the engine cannot continue trying to run with the key off.
Not sure why it was disabled, since it doesn't affect how the car runs. Perhaps some other component was changed (like the carbs, ignition switch or oil pressure switch) so it no longer worked anyway. Or maybe someone just didn't like pollution controls :smile:
S
ScottFromNH
Hey Tr3driver,
thanks for the information. I guess I will have to wire it back up and see what it does. From what I can tell nothing has been changed on the car and after looking at photos I can tell the anti run on valve is suppose to be wired and it has nothing connected to it.
S
ScottFromNH
Oh great thanks for the link and yeah I am totally interested.. This is my first british rebuild and never did anything in this bad of shape so just trying to figure out what things are and how they work and why he disabled them or cut the wires.
poolboy
If those wires do belong to the ARV circuit, the positive wire is "hot" when the ignition key is in the "OFF" position so be careful you don't strike a ground when you're fooling with it.
The ground wire for the ARV will originate at the oil pressure warning switch screwed into the engine block. Your saying that there are 2 wires at the firewall has me wondering if they are both truly part of the ARV circuit.
S TR6 Anti Run-On Valve question. Triumph 4
G TR6 Anti run-on valve question for 73 TR6 Triumph 3
G Anti-sway bar question Spridgets 1
bigjones Sway bar [anti-roll bar] question Spridgets 8
N Rear anti-roll bar installation question? Triumph 1
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
