TR6 Anti Run-On Valve question.
Sbardon
Member
1976 TR6
Anti Run-On Valve.
I think it is leaking....
As the Vacuum connection to the banjo on the intake manifold is what draws through the valve, I disconnected the line at the banjo and attached a hand vacuum pump to the line.
It would not hold vacuum, Very quick (not instant) drop.
The anti run-on valve should hold vacuum correct?
Just looking for confirmation before I tackle it.
thanks,
Stephen
poolboy
See if I have this right...
You unplugged the ARV hose from the intake manifold's Banjo Fitting and 'sucked' into the hose and ARV with a vacuum pump, but the Vacuum would not hold.
If I got that right, then see if vacuum holds when the ignition key is in the ON position.....you may want to disconnect the wire feeding voltage the coil during the test, though..
S
Sbardon
Member
Poolboy, Thanks, I went farther, took the unit off the car, so no power, the manifold vacuum port should be closed. Cleaned it best I could soap and water, and ran water through it to rinse... it still behaves the same.
The real question is whether or not it is suppose to hold vacuum, I am not sure how the solenoid plunger is vented... thought perhaps it is supposed to have a slight leak as per solenoid venting.
The unit is $$ don't want to order a new one and find out mine is ok.
poolboy
Sure, it's supposed to withstand vacuum until it opens, but why do you need it in the first place ?
Cap the nipple tightly on the banjo fitting and see ? Run-on was mainly because of the gasoline we were getting during the Arab Oil Embargo
S
Sbardon
Member
Poolboy, thanks an understood, just being a stickler about getting everything in the car working right. I can plug it for tuning... then see if it makes any difference when unplugged. I am chasing a serious vacuum issue, just one thing to take off the list.
D TR6 Anti run-on valve Triumph 3
S Spitfire Question on anti run on valve 73 spitfire Triumph 5
H Anti run on valve MG 6
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
2wrench Pics showing repair to anti-run-on valve. Triumph 1
Brosky Anti-run valve wiring fix - who posted it? Triumph 29
KLUTZ Anti-run-on Valve in a '71 MG 19
B Emission ???'s EGR; Anti Run-On valve etc... Triumph 3
G TR6 Anti run-on valve question for 73 TR6 Triumph 3
philman Wedge tr7 anti run on valve Triumph 1
Steve Anti run-on valve MG 5
steveg Anti-run on solution Austin Healey 10
ecurie_ecosse T-Series Anti run on switch. MG 11
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
T Need an Anti-Tramp Bar? Austin Healey 6
FlyingCat Spitfire Anti-Roll Bar Triumph 6
Bob_Spidell Healey Anti-Theft Device Austin Healey 0
JimLaney Anti-seize or Thread locker ? Spridgets 2
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
J Healey BJ8 anti roll bar bushes Austin Healey 2
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
B Anti-sway bar for a earlier BJ7 Austin Healey 3
bugedd Front anti roll bar Spridgets 11
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
tomshobby Have you checked your anti-freeze? Spridgets 1
tahoe healey disc brake anti squel pads Austin Healey 5
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
Ed_K Installing new anti-sway arm bushings Austin Healey 3
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
J Anti corrosion strips - Worth it? Austin Healey 8
G Anti-sway bar question Spridgets 1
HAN8L1965 CounterAct electronic anti rust system? Spridgets 22
Got_All_4 TR5/TR250 ADCO Anti sway bar installation on the Tr250 Triumph 4
jerrybny Anti-Rattle Spring and Plunger Triumph 4
jerrybny Anti-Rattle Spring Triumph 1
