Emission ???'s EGR; Anti Run-On valve etc...
boston
Hi All,
Ran into this web site the other night and thought it was great. So I joined. I have a 74 1/2 Tr6. Bought it new. Not in the best of shape but still driving it evey summer (Michigan). Looks good from 50 yds..Pimento Red. Two years ago spent the winter rebuiding the front steering and suspension;back suspension;new redlines and brakes. Last year I rebuilt the Carbs. Messed around allot with the timing and air/fuel ratio. I burn 93 unleaded. It ran good but wonder if it could be better. Which brings me to my question. I don't have an EGR or Anti run-on valve on the car anymore (has been 10+ yrs).The evap cannister is still hooked up but everything else is plugged. The 74 1/2 was just before the air pump was "forced" on the car. Any suggestions or questions would be greatly appreciated.
Boston Bob
swift6
Welcome to the mental ward. /ubbthreads/images/graemlins/jester.gif
Seriously, this is a great resource and a very friendly place.
My '72 TR6 was Pimento when it left Coventry. Now its not.
G
Try running centrifugal advance instead of vacumn advance. Flip the timing over to about 8 degrees BTDC. Works for me.
Hotter coil, open a few gaps, basic tuning tricks.....
Not for everybody.
Bill
B
boston
Hi Bill,
What do you mean by "open a few gaps"? I've read a few times where people have not used the vaccume from the carbs and blocked it off at the dist..Any thoughts on the emission crap?
Bob
R TR6 Questions on emission tank-to-canister pipe Triumph 0
FlyingCat Spitfire Emission Controls Triumph 3
M Emission Levels Austin Healey 1
M Carb emission test Austin Healey 5
Y Spitfire removing emission control system Triumph 1
I TR6 Emission Control label for 69 TR6 Triumph 1
S people at emission Other British Cars 0
S people at emission Other Cars 7
S people at emission Triumph 3
7 79 midget 1500 Emission Removal Spridgets 3
knad2208 Bypassing Emission Controls Spridgets 11
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
M Gas, hot days, carburetors and emission control... Spridgets 19
M Emission control question Spridgets 0
B TR6 TR6 Bonnet Latch Cable/1972 Emission pic Triumph 31
Baz Emission control & canister Spridgets 6
S CA Emission Laws MG 41
7 d@%# emission test MG 1
A Emission - FAILED! Spridgets 10
T EMISSION VALVE is it needed Triumph 2
W MGB MGB Emission Control I Need Help Please MG 6
D Who ripped out their Emission System? Tips? MG 3
Coyote1 TR6 TR6 EGR Valve Delete ? Triumph 9
Dudly The value of an EGR Triumph 17
wangdango TR6 76 TR6 pcv/egr? Triumph 2
davidk How to Seal Plug for EGR hole in head Triumph 3
Morris EGR::FAIL Spridgets 1
ronzet Needed EGR valve for a 1979 MG Midget Spridgets 20
B EGR and Ignition light Spridgets 0
M **Midget EGR Valve- CA Emissions Spridgets 6
Steve1970 Replacing EGR valve with suitable plug Triumph 9
T TR6 egr thread size? tr6 Triumph 6
C 1500 EGR Valve Spridgets 4
C Wedge TR-8 EGR on a Spitfire? Triumph 1
Aldwyn Thoughts on EGR Valves? Triumph 12
B TR6 TR6 EGR Thread? Triumph 12
T TR6 TR6 EGR/Emissions Question Triumph 2
Nunyas EGR Valve and heat shields MG 24
KLUTZ Wedge Removing my EGR on TR7 Triumph 0
H EGR valve Triumph 4
L EGR Light Triumph 1
Glennyboy Wedge TR8 EGR Valve Triumph 0
johnrip Wedge egr valve on tr7 Triumph 3
H EGR Valve questions Triumph 4
R TR6 TR6 EGR valve Triumph 12
S Wedge TR7 EGR Triumph 5
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
