Spitfire removing emission control system
ylvieken
hello,
i resently baught a triumph spitfire 1500 with emission control system(2canisters,vacuum pipe to manifold,air pump,egr valve and a lot of hoses) is it possible to remove all this?dont i have to change the carburettor?(single zenith cd carb is mounted now)or can i just plug the holes for the hosses from the emission control system on my carburettor .and can i plug the hole on the cranckcase,or does it have to go to the carb.excuse me for my bad english but im doing my best
thanks,regards
AEW
I think there are three answers:
First, and most true, is you should fix it to proper working condition and see if you like it. Pollution equipment wears out at least as fast as any other part of the car. Your Spit is I'm guessing early 80's? The pollution stuff was pretty much designed in to the engine.
Second, and only if it is legal where you license the car, you can alter the parameters of the pollution equipment to get by some of the most annoying characteristics. For example an EGR system can have the vacuum delay replaced with a slower responding unit. That takes the edge off the power drop when it opens a little. The air injection bothers people who think it draws horsepower, which it does a little. A larger diameter pulley will reduce the load at the expense of pump output and delay some of the catalytic converter function. (personally I never felt manifold after-burn was helpful). A functioning converter is actually a good thing. The cam characteristics are not adjustable, as are not the advance curve of the stock dist.
Third answer is not for most owners. You can "revert" the drive-train to the type in non-pollution equipped cars. You probably need a lot of parts from an older Spit. Again, check what your laws allow for the age of your vehicle.
btw. long ago I was an inspector for my environmental agency.
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
KVH TR4/4A Removing the Differential Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
