I have an old Gunsen gas analyser, had it for years so I don't think it's very accurate. Just for curiosity I tried it out on my recently acquired BJ8.
I tried it out on each exhaust pipe in turn. The front carbs gave a reading of 9.5% CO but the rear carbs gave 6.8%. As I said I don't think the numbers mean much but the difference between the readings should be reliable. The timing is set at 16 degs with a strobe and the plugs do look a little dark.
The rear carbs are much leaner than the front which might explain why it takes a little while to start from cold in the morning when it pops and bangs a bit. Otherwise the car runs well and starts first time without the audio effects after the initial start up.
Does anyone have any suggestions as to whether I should enrichen the rear carbs or back off on the front. It has a fast road engine in it and the garage I bought it from said it likes to run slightly rich.
Thanks
AJ
Thanks
AJ
