Spitfire Anti-Roll Bar
FlyingCat
Hi, everybody! I got my 1980 Spitfire (Federal, 1500) running, and now I'm realizing just how squirrelly the front end is. The bracket where the Link Ends hook onto the Lower Wishbone appears to be broken on each side. It's obviously broken on the LH, and the Link End is loose on the RH. Those brackets appear to have been reinforced on both sides. As it is, I don't think welding them again is going to do much good, so I'm probably looking at replacing both Wishbones and the Link Ends while I'm there. So here's my question: Are those brackets where the Link Ends bolt onto the Wishbone just inherently prone to breaking? If they are, would it do any good to just go ahead and reinforce the new one before I put it on the car? Any ideas?
Ignore that my pictures always come in any way but right. The left one is obviously broken, and I'm pretty sure there shouldn't be any play in that bolt on the right if it were functioning correctly, but then, I truly don't know.
Thanks already!
Andrew Mace
I have seen problems in that area, but not all that frequently. (For example, in well over a dozen Heralds, along with Spitfires and GT6s, I've never had it happen.) Meanwhile, someone certainly has already tried to make some sort of "repair" on the RH link.
If the car were mine, I'd be looking for better lower A-arms. Period.
FlyingCat
FlyingCat
I'm with you on getting better Wishbones. I haven't really looked yet, but hopefully that's something that won't be too terribly hard to find. Thanks!
Andrew Mace
A quick scan of eBay under "Triumph Spitfire A-arm" or "Triumph Spitfire control arm" should bring up several from which to choose. Also, check your local Craigslist and such, try contacting local Triumph clubs, Facebook marketplace...all sorts of options. Shouldn't be difficult to find a good pair!
FlyingCat
FlyingCat
That's what I thought about the radiator bracket... but I ended up needing to get it fabricated... which ain't cheap. But, yeah. I will find them, and they don't appear that difficult to put on the car. I wanted a project when I got this car, and it hasn't let me down. Thanks!
sp53
Glad to hear the flying cat is air born; I remember how you stayed after it--- good job; these cars have a therapeutic valve or as my stepfather would you say,” would you rather have her sitting on a bar stool?” He actual owned a bar. Anyways, I am with Andy there are Spitfires all over the Seattle Craigslist. I would look around and buy a whole car. You are going to need body and suspension stuff you never thought you would. So find a good body and suspension; do not worry about the running gear too much that stuff will be around. Sheet metal goes first then suspension.
FlyingCat
FlyingCat
Luckily I'm not in Seattle, as far as corrison goes. I'm in Portland, not that it's much of an improvement. However, my car spent most of its non-running life in La Grande, Oregon, which is on the high desert side of the state, so the body is good. There's only a little rust in the trunk, which will be an easy fix... and that's it. Even the underside is in good shape. At this point, I'm looking to replace the wishbones on both sides, and stop there... for now. Truly, the suspension looks fine, aside from anything with rubber on it, and I've already replaced most of that.
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
J Healey BJ8 anti roll bar bushes Austin Healey 2
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
bugedd Front anti roll bar Spridgets 11
Hairyone Anti-roll bar Spridgets 13
bigjones Sway bar [anti-roll bar] question Spridgets 8
N Rear anti-roll bar installation question? Triumph 1
J Anti-roll bar Austin Healey 1
Tronch Rear shocks and anti roll bar Austin Healey 4
bash Front anti-roll bar link MG 3
Baz Anti-roll bar.... Racing 2
John_Mc Anti roll bar bushing installation Triumph 8
C Anti-roll bar installation Austin Healey 7
H anti roll bar Austin Healey 22
Jake Rear anti roll bar - remove or not? MG 3
M MGB MGB Anti-Roll Bar MG 4
S BJ8 anti-roll bar Austin Healey 2
B Spitfire Spitfire Mk1 Rear Anti Roll Bar / Sway Bar Triumph 3
S E-type IRS Anti-Roll [or sway] Bar Jaguar 0
Nunyas Rear Anti-sway/Anti-roll bars... MG 6
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
T Need an Anti-Tramp Bar? Austin Healey 6
S TR6 Anti Run-On Valve question. Triumph 4
Bob_Spidell Healey Anti-Theft Device Austin Healey 0
steveg Anti-run on solution Austin Healey 10
JimLaney Anti-seize or Thread locker ? Spridgets 2
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
B Anti-sway bar for a earlier BJ7 Austin Healey 3
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
tomshobby Have you checked your anti-freeze? Spridgets 1
tahoe healey disc brake anti squel pads Austin Healey 5
D TR6 Anti run-on valve Triumph 3
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
S Spitfire Question on anti run on valve 73 spitfire Triumph 5
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
Ed_K Installing new anti-sway arm bushings Austin Healey 3
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
