Rear anti-roll bar. Is it worth installing on a BN1?
55modified
So I am trying to upgrade my suspension wherever I can. Koni shock kit installed in the front, lowered 1/2" with original coil springs. Rear has original panhard rod and tracking arms. Car has GM 12 bolt rear. I was looking at Dennis Welch or other upgraded rod. Any suggestions or advice from anyone who has done this would be appreciated.
John Turney
I have the Denis Welch front anti-roll bar and 1.5 deg. negative camber in front, track bars in the back to limit rear spring wind-up. I upgraded the original Panhard rod with Poly bushings and broke the welds on the axle bracket. Steve Gerow (steveg) broke his also with the Cape International modified Panhard rod. Make sure your rod brackets can take the additional load. I've modified the axle mount to, I hope, prevent further breakage.
I don't recommend the rear anti-roll bar as it increases understeer. What I would recommend if you don't have it as a limited-slip differential.
Michael Oritt
John--
A rear anti-roll bar will decrease understeer as it stiffens the back and increases grip in front.
Conversely a stiffer front anti-roll bar tends to induce understeer as it decreases front lean and--relatively--lessens the grip of the front tires.
Of course all of this is theoretical and YMMV in the real world.
On my car I have both increased the diameter of the front anti-roll bar and added the DW bar in back to reduce total body roll which keeps, relatively speaking, the car's tendency to have inherent understeer.
55modified
55modified
Thanks I think I will leave it alone. I do have a limited slip recently installed when I did a gear swap from. Traction bars from PO too.
steveg
Have to say, after my experience, I regard the whole idea of the "uprated" panhard bar as a crock. The racers can chime in on this, but the stock bar with rubber bushings at both ends is more than up to the job.
DerekJ
Steve, I agree with you re the Panhard rod. The load is the same whether the rod is original or thicker. If the original holds up, which it does, then there isn't a problem. A rear sway bar just isn't necessary as we already have a solid rear axle which is pretty much doing the same job.
Michael Oritt
Derek--
I agree that simply increasing the diameter of a panhard bar brings nothing to the table and so long as the original one is heavy enough to not break while locating the axle under transverse loads that's fine. What can be helpful is to modify its attachment points to the frame and/or the axle so that it is on the same plane as the axle and replicates its geometry as much as possible.
I don't agree that a rear anti-sway bar is unnecessary and it performs the same job in the rear as does a heavier bar in the front: It resists the tendency of an opposite wheel to lift and thus increases traction. The rear axle's being solid provides some, but not much, of this effect. But if we are talking about increasing suspension performance such a bar in back is no less necessary than having one in front--or upgrading suspension performance in the first place!
DerekJ
Michael
The front needs a sway bar much more than the rear due to the independent suspension set up as opposed to the solid axle at the rear.
i agree on the necessity of the Panhard Rod being on the same plane as the axle. If not it can produce weird effects such as rear wheel steer.
Michael Oritt
Derek--
I am not saying that a rear anti-sway bar is absolutely necessary. However I believe we have been talking about increasing the diameter/weight of the front bar and to my mind doing that modification alone will produce excessive understeer which a rear bar would offset. In other words if you increase/decrease the body lean/traction at one end you should do it at the other or face what would be an undesirable change in handling, etc. etc.
Again, one's mileage may vary....
55modified
55modified
So is anyone here running a rear sway bar on their car?
DerekJ
I think its important also to differentiate between normal road use and setting up a track car. A rear sway will increase the tendency to oversteer which is not what you want in a road car.
Deleted member 19315
Hi Derek, when rebuilding my 100/6 I did fit a rear anti roll bar from DW. My thinking was that while I was under the car I my as well weld in the fittings and if it didn't suit its easy to remove the bar. I agree with most of the preceding discussion by the way. To get to my point, this car has all poly bushes the 7/8 front bar, negative trunnions ( which only give a measured 1 degree) up-rated lever arms. It has worked over BJ8 front springs and reprofiled rears to give a 1 1/2inch lower all around. I have 72 spoke 5.5 rims with veredstien tyres. I also have a tight plate type lsd.
My thinking with the rear bar was it may counteract to some extent the understeer affect that the lsd tends to generate when not 100 % committed to corner entry. What do you think?
By the way I recognise the difference between road and race and am no race driver I just like the feel of a more competition flavoured car.
steveg
As I understand, if you do your front and rear bars a certain way, you'll have a neutral-handling car - i.e. one where the front and rear wheels let go at the same time. Most say an understeering car is safer for ordinary drivers.
If Mike Salter's reading this discussion, he may want to contribute his bad experience with a rear bar.
55modified
55modified
Tell us more about your coil springs. They aren't just chopped are they?
I have looked for shorter springs and can't find them or anyone to custom fabricate. So I got Tom's 1/2 lowering kit.
I tried BJ8 springs on advice and they sat taller than stock BN1.
When my Healey was an active autocross contender, I ran a 3/4" rear bar in conjunction with a heavier 7/8" front bar, both sourced from Addco, IIRC. Under those conditions it was a big improvement over the stock configuration (and easily rotated with the throttle).
Tube shocks were still a no-no in the street prepared category, so the valves in the stock (new replacement) Armstrong shocks were shimmed and tightened up a bit, along with variety of Castrol motorcycle fork oil viscosities.
When I tore the car down for restoration in 1986, I did away with the rear swaybar AND the Panhard rod, and fitted an articulated A-arm to locate the axle instead. Try as I might, it is very difficult to induce either under or oversteer__I don't know if the tires are that much better, or if I just lost my nerve, but the car seems to be very well planted now, with neutral balance
Overall, my impressions through decades of modifications align with Michael's observations.
Hi. I had the end coils closed up to reduce the overall height but keep the standard "rate". They were done for me so I don't have any detail I'm afraid.
N Rear anti-roll bar installation question? Triumph 1
Tronch Rear shocks and anti roll bar Austin Healey 4
Jake Rear anti roll bar - remove or not? MG 3
Nunyas Rear Anti-sway/Anti-roll bars... MG 6
B Spitfire Spitfire Mk1 Rear Anti Roll Bar / Sway Bar Triumph 3
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
Got_All_4 Matching front and rear Anti sway bars Triumph 2
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
