Rattle in the boot
David_Doan
I know it probably sounds silly to chase rattles in a Bugeye, but this one is very repeatable.
It sounds like there is a loose piece of metal in the boot - like a nut or washer. Sometimes I hear it rattle, sometimes I hear it slide or roll when I go around a corner, but I can't find it. At this point I think it is in the gas tank.
Before I dive into the gas tank, does it have a flexible pick-up tube with a metal end that might be making this noise?
Thanks,
David
Westfield_XI
You don't think it might be Junk in the Trunk or Loot in the Boot.......
Sorry, I couldn't resist........
mightymidget
exhaust, jacks, even round object in trunk, not the gas tank. all one piece..........unless someone (kid) drop something in it when you were not looking....now that would be away to pay back
I've had a weird clunk in the boot since last summer. Finally decided to see what had been left back there ... spare half shaft that I packed for my trip to Wisconsin. :crazyeyes:
daveu
Member
I took the gas tank off my Midget to repair a leak and found about 10 rocks in it. I'm wondering if that was the noise I was hearing in the back last summer.
AN5Sprite
In my first Bugeye I heard a rattling/rolling sound coming from the fuel tank. What I found inside was two small stones and 3" long spring. Locking gas cap ever since then... :crazyeyes:
daveu
Member
Had the Midget out for a drive yesterday and the clunk in the rear is gone. Must have been the rocks in the gas tank.
R Fender Spear Potential Rattle Austin Healey 6
K TR2/3/3A Timing chain rattle on start up? Triumph 2
M MGA MGA Engine Rattle MG 10
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
BoyRacer Rattle can Healey Blue paint Austin Healey 2
KVH Rattle Can Problems Restoration & Tools 5
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
C BN1 Clutch Pedal Rattle Austin Healey 2
B MGB-GT Need help with MGB GT rattle MG 0
S TR2/3/3A Rattle Triumph 9
S TR2/3/3A some rattle can primmer Triumph 9
warwick-steve Mystery Rattle Austin Healey 21
S TR2/3/3A Hood - Rattle Triumph 15
R TR2/3/3A Clutch rattle/clack-!957 TR-3 Triumph 10
S Colorado Red - is there a close approximation in rattle can? Austin Healey 4
T TR2/3/3A Rear shocks and rattle Triumph 5
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
Joe Reed MGB Rattle under front end? MG 8
PatGalvin TR2/3/3A Bonnet Prop Rod Rattle Triumph 20
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
vette A Rattle, no no it can't be. Austin Healey 8
B Door rattle Austin Healey 0
RJS TR4/4A Hood/Bonnet Prop Rod Rattle Triumph 10
D XJ6 series III front end rattle Jaguar 5
RickB "Finished" my rattle can paint job Spridgets 19
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
AUSMHLY Does your window rattle when in the down position? Austin Healey 3
R Rattle that won't go away Spridgets 6
memphis Door Rattle Austin Healey 3
tri_carb_healey 3000, starter rattle? Austin Healey 14
RickB Rattle can advice please Spridgets 76
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
AngliaGT MGB-GT GT Shifter Rattle MG 4
Jer rear suspension rattle/squeak/clunk remedy... Spridgets 20
cdsmith brake shoe rattle? Spridgets 10
jerrybny Anti-Rattle Spring and Plunger Triumph 4
jerrybny Anti-Rattle Spring Triumph 1
jerrybny Dreaded Stick Shift Rattle Triumph 2
Moseso TR2/3/3A TR3 Bonnet Rattle Triumph 24
zimmy anti rattle spring and plunger Spridgets 21
I TR6 TR6 Shake, Rattle and Roll Triumph 18
CCURTISS T-Series MGTF Shifter Rattle??? MG 4
tosoutherncars Rattle on startup - 1500 Triumph 5
B TR6 TR6 Disc Brake rattle Triumph 2
71tr Rattle Cans and Dependable Suppliers Triumph 14
sim Rattle limiter is gone Spridgets 6
