Rattle on startup - 1500
tosoutherncars
Hi all,
I've got a 1500 engine (Midget) and on start-up I get a rattle for about a second before it settles into an idle. It appeared (or at least, became more evident) after a recent oil & filter, and switch to 20W50.
Hard to convincingly describe sounds, but it's quite 'hollow', almost like someone shaking a ball bearing in a tin can.
It's been a couple thousand miles since the valves have been set, don't know if something may have closed up on me? And if it were a valve, would it then go away?!?
But otherwise... possibilites, starting with the best first? :wink:
aeronca65t
I forget exactly how it works on street 1500s (my race car has a unique oil filter setup), but I think you have to be careful that you've got the oil filter with the anti-drainback valve or the filter will drain down when the engine is shut off.
And then, during a re-start, it will run without oil pressure until the filter re-fills (this is a real bad situation, I'd think).
Since you just changed the filter, that makes me wonder.....
(I seem to re-call this is a similar deal with oil filters on MGBs....someone else want to chime in here?)
AltaKnight
Does the filter sit vertically or is it at an angle or worse still horizontal?
If it's vertical then it shouldn't matter (I think) about anti drain back construction.
You may have excessive clearance on the bearing journals (mains and/or rod bearings) How's your oil pressure (does the car have an oil press gauge?), what does the pressure do at startup.
The oil pump clearances may be too wide meaning it's struggling to prime itself on startup.
I doubt it's a valve clearance issue; that usualy manifests itself as a tapping sound rather than a rattle.
Probe with a screwdriver with the handle against your ear to locate where the sound is emanating (be real careful about the fan/belt and loose clothing though.
R Fender Spear Potential Rattle Austin Healey 6
K TR2/3/3A Timing chain rattle on start up? Triumph 2
M MGA MGA Engine Rattle MG 10
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
BoyRacer Rattle can Healey Blue paint Austin Healey 2
KVH Rattle Can Problems Restoration & Tools 5
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
C BN1 Clutch Pedal Rattle Austin Healey 2
B MGB-GT Need help with MGB GT rattle MG 0
S TR2/3/3A Rattle Triumph 9
S TR2/3/3A some rattle can primmer Triumph 9
warwick-steve Mystery Rattle Austin Healey 21
S TR2/3/3A Hood - Rattle Triumph 15
R TR2/3/3A Clutch rattle/clack-!957 TR-3 Triumph 10
S Colorado Red - is there a close approximation in rattle can? Austin Healey 4
T TR2/3/3A Rear shocks and rattle Triumph 5
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
Joe Reed MGB Rattle under front end? MG 8
PatGalvin TR2/3/3A Bonnet Prop Rod Rattle Triumph 20
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
vette A Rattle, no no it can't be. Austin Healey 8
B Door rattle Austin Healey 0
RJS TR4/4A Hood/Bonnet Prop Rod Rattle Triumph 10
D XJ6 series III front end rattle Jaguar 5
D Rattle in the boot Spridgets 7
RickB "Finished" my rattle can paint job Spridgets 19
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
AUSMHLY Does your window rattle when in the down position? Austin Healey 3
R Rattle that won't go away Spridgets 6
memphis Door Rattle Austin Healey 3
tri_carb_healey 3000, starter rattle? Austin Healey 14
RickB Rattle can advice please Spridgets 76
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
AngliaGT MGB-GT GT Shifter Rattle MG 4
Jer rear suspension rattle/squeak/clunk remedy... Spridgets 20
cdsmith brake shoe rattle? Spridgets 10
jerrybny Anti-Rattle Spring and Plunger Triumph 4
jerrybny Anti-Rattle Spring Triumph 1
jerrybny Dreaded Stick Shift Rattle Triumph 2
Moseso TR2/3/3A TR3 Bonnet Rattle Triumph 24
zimmy anti rattle spring and plunger Spridgets 21
I TR6 TR6 Shake, Rattle and Roll Triumph 18
CCURTISS T-Series MGTF Shifter Rattle??? MG 4
B TR6 TR6 Disc Brake rattle Triumph 2
71tr Rattle Cans and Dependable Suppliers Triumph 14
sim Rattle limiter is gone Spridgets 6
