Rattle limiter is gone
sim
HI all
Just a short note to let you all know I have the 58 sprite back on the road. Put in a rebuilt rib tranny and a 1275 front damper pulley, new front seal and new gaskets.
Now I just have 2 problems one is my Rattle limiter is gone. I used this rattle as a point to back off on the gas. The other is, it no longer marks it territory.
I now have a smooth ride and I hope the whine in the gears quites after it runs in a bit.
Thanks again for all your help.
Time to paint it.
Sim
JPSmit
congrats! no rattle limiter - drive it like you stole it!!! you got pictures?
jlaird
Congrats, job well done.
tosoutherncars
sim said:
(...) I used this rattle as a point to back off on the gas.
I use the point at which passengers start checking their seat belts and/or holding onto the windshield frame! Always worked fine... =D
jlaird
I back off when I start to slide out of the seat without a seat belt. With a seat belt I have never found a need to back off, a Bugeye is controlable right up to the time it spins and even then, because of the low power, that is controlable.
sim
sim
I will send pictures after I paint it. last time it was painted was 30 years ago and has not seen a garage during that time
Just a rain tarp.
but there is one problem and I think it is the timming chain cover did not seal right as it is now marking its territory again.
I will check closer to make sure then get back in there and r n r the cover
Thanks
Sim
R Fender Spear Potential Rattle Austin Healey 6
K TR2/3/3A Timing chain rattle on start up? Triumph 2
M MGA MGA Engine Rattle MG 10
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
BoyRacer Rattle can Healey Blue paint Austin Healey 2
KVH Rattle Can Problems Restoration & Tools 5
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
C BN1 Clutch Pedal Rattle Austin Healey 2
B MGB-GT Need help with MGB GT rattle MG 0
S TR2/3/3A Rattle Triumph 9
S TR2/3/3A some rattle can primmer Triumph 9
warwick-steve Mystery Rattle Austin Healey 21
S TR2/3/3A Hood - Rattle Triumph 15
R TR2/3/3A Clutch rattle/clack-!957 TR-3 Triumph 10
S Colorado Red - is there a close approximation in rattle can? Austin Healey 4
T TR2/3/3A Rear shocks and rattle Triumph 5
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
Joe Reed MGB Rattle under front end? MG 8
PatGalvin TR2/3/3A Bonnet Prop Rod Rattle Triumph 20
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
vette A Rattle, no no it can't be. Austin Healey 8
B Door rattle Austin Healey 0
RJS TR4/4A Hood/Bonnet Prop Rod Rattle Triumph 10
D XJ6 series III front end rattle Jaguar 5
D Rattle in the boot Spridgets 7
RickB "Finished" my rattle can paint job Spridgets 19
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
AUSMHLY Does your window rattle when in the down position? Austin Healey 3
R Rattle that won't go away Spridgets 6
memphis Door Rattle Austin Healey 3
tri_carb_healey 3000, starter rattle? Austin Healey 14
RickB Rattle can advice please Spridgets 76
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
AngliaGT MGB-GT GT Shifter Rattle MG 4
Jer rear suspension rattle/squeak/clunk remedy... Spridgets 20
cdsmith brake shoe rattle? Spridgets 10
jerrybny Anti-Rattle Spring and Plunger Triumph 4
jerrybny Anti-Rattle Spring Triumph 1
jerrybny Dreaded Stick Shift Rattle Triumph 2
Moseso TR2/3/3A TR3 Bonnet Rattle Triumph 24
zimmy anti rattle spring and plunger Spridgets 21
I TR6 TR6 Shake, Rattle and Roll Triumph 18
CCURTISS T-Series MGTF Shifter Rattle??? MG 4
tosoutherncars Rattle on startup - 1500 Triumph 5
B TR6 TR6 Disc Brake rattle Triumph 2
71tr Rattle Cans and Dependable Suppliers Triumph 14
