3000, starter rattle?
tri_carb_healey
hey guys
I TRIED TO START MY HEALEY THIS morning and the motor turned a couple times and then the starter began to rattle and the motor stopped turning. my dad would know wut to do but he passed recently and i wanna get the old girl running any tips would be greatly appreciated any help physically would be compensated. fire away!!!
red57
Are you hearing the buzz of the solenoid from a low battery? Check voltage at the battery or put a charger/jumper on and see if the 'rattle' goes away.
That's my guess - you guys in Florida have been having colder than normal weather & may be exposing a dead/dying battery.
This starter doesn't rattle...
... it rocks!
tri_carb_healey
tri_carb_healey
did you get that from moss, i bought a replacement starter from moss like two years ago and the starter itself doesn't rattle it just sounds like it. i should have described it better, but the starter i have in the car now is very simlar to that.
Johnny
If the starter is original the cables may be rotten. Hard to see until you remove them and open up the rubber insulation. They may look okay, sometimes if you bend them you can hear a 'crunching' sound which is a good indicator. First, as mentioned, I'd check the battery at the solenoid. If it's original, you can press on the back of the solenoid and turn the starter over. Sometimes the solenoid gets 'stuck'.
Legal Bill
If a charge to the battery and a check of the connections does not fix it, try to determine if the noise you are hearing is the starter spinning without engaging the flywheel and turning the engine. It can sound like a buzz or a growl more than a rattle. There can be a couple of causes, but it usually requires that you remove the starter to investigate further.
tri_carb_healey
tri_carb_healey
thanks guys!!! i put the battery back in after a full charge and the motor started turning again!! i was not looking forward to a starter inspection.especially because i wouldnt know what to look for this thing is completely different from the original which lasted like forty years.
the next step will be solving why the car sputters and stalls when i try to move it. after some fiddling if nothing happens ill post the dilemna for u brittish car gangsters out there. thanks again
tri_carb_healey
tri_carb_healey
fuel pump is good i believe the problem lies in the carbs, i know how to take apart and fiddle with the floater assembly, but ive never removed the dashpot and further more when i do remove it ill have no idea wut inspect for issues. the post will come up soon after i mess with the carbs a little.
Legal Bill
They have manual chokes that must be used until the cars warm up a bit. If you just use the choke to start the car and then push it back in, the car will sputter.
tri_carb_healey
tri_carb_healey
the first of the three carbs likes to spill gas from the top of the carb is this a fault of the floater itself or the "tppet assembly above it?"
Legal Bill
If the gas is coming from the bowl overflow tube (or hole if there is no tube), the problem could be:
1. Poorly adjusted float
2. leaking float
3. Worn needle valve
4. Worn valve seat
5. Dirt or rust stuck between the needle and seat
Disconnect the fuel lines to the bowl, unscrew the screw holding the cover on the bowl, remove the cover and all the above potential problems will be right in your hand.
tri_carb_healey
tri_carb_healey
i have these crappy plastc valve seats, do u know where i can find some brass ones, i got the from victoria brittish
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
davidb AH 3000 gear reduction starter Austin Healey 13
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R 3000 Heater Valve Austin Healey 4
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Bruce 3000 Rally Grille Installation Austin Healey 5
J 3000 Rear Seats Austin Healey 6
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
M Engine Stand for 3000 Motor Austin Healey 7
D Healey 3000 BT7 rear panels Austin Healey 0
BoyRacer Mystery 3000 Engine Block Austin Healey 2
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
Zitch For Sale AH 3000 Engine For Sale: $2500 Denver, CO area Austin Healey Classifieds 0
C Rough-Running 3000 Austin Healey 29
E 3000 Healey Door Checks Austin Healey 1
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Editor_Reid In Search Of: AH 3000 BT7L 8921 Austin Healey 0
Z 3000 Front Wheel Bearings Austin Healey 3
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
Guido36 Healey 3000 cutaway display engine Austin Healey 12
pbraun For Sale Healey 3000 transmission Austin Healey Classifieds 8
O HD8 carb on Healey 3000 Austin Healey 62
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
C Austin Healey 3000 in Modsports Austin Healey 4
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
M 3000 BJ8 Door Seals Austin Healey 9
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
A AH 3000 rear disc brake conversion Austin Healey 28
