Passenger interior door handle issue [1960 BT-7]
B
Bobbee44
The passenger side interior door handle, when pulled back to the stop position, does not fully pull the bolt from the striker plate. The exterior handle, on the other hand, works exceptionally well. My preferred passenger, aka my wife, has no problem reaching over the sill to open her door from the outside; however, in inclement weather with side screens, this feat will be much more difficult.
Before I launch into removal of the door panels, will I find that there is a relatively easy fix?
Thanks,
Bob
richberman
Thanks,
Bob
You'll need to bend the interior bar until it works well. You might only have to remove the interior panel, not the ones inside the door.
Rob Glasgow
I had the same issue on the drivers side door of my BT7. Turned out that the “door latch assembly” that holds the pin that enters the striker plate had cracked and was "spreading' when I pulled the interior handle and would not retract the pin enough to allow the door to open. My outside handle worked fine like your's. I had to buy a replacement mechanism from Moss. That fixed the issue. The latch assembly is item 10 on the Doors and Fittings page.
Keith_M
The answer is obviously to not get out of the car in inclement weather.:glee:
I fixed this same problem in my BT7 by bending the bar connecting the handle and the latch as suggested by Rich. This also cured the bar of rattling when the door was slammed because it was now a tight fit between the latch and handle. You shouldn't have to remove any panels to try this fix. If it doesn't work, then you will have to remove panels and look for another problem like the one Rob described.
B
Bobbee44
Thanks guys. As always, good advice. I will spend some time this wekend and hope that a bend will mend.
Bob
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
K TR2/3/3A Passenger side fender mirror....... Triumph 13
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
Jim_Stevens TR2/3/3A Firewall passenger side Triumph 2
charlie74 Wanted Passenger seat replacement foam [‘74] Triumph Classifieds 0
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
S TR2/3/3A passenger door Triumph 24
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
B Wanted TR250 passenger seat Triumph Classifieds 0
A TR6 '73 tr6 passenger front brake dragging Triumph 2
Jim_Gruber BE Passenger seat bases Spridgets 6
richberman Longbridge passenger lock chrome lever anyone? Austin Healey 8
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
D Poor fit door and glas to top on passenger side. Austin Healey 7
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
T TR6 Passenger side TR6 rear clunk? Triumph 9
D Spitfire WTB window regulator, passenger side, '65 Spitfire Triumph 3
Tr3aguy TR2/3/3A Looking for a passenger door!!! TR3 Triumph 20
Boink Passenger Parcel Shelf in a Bugeye Spridgets 25
H Tailpipe exhaust back into passenger compartment Austin Healey 26
brgrmyster GT6 GT6 Mk 1 Passenger Foot Rest? Triumph 3
T Wedge TR8 scraping noise from the passenger side rear Triumph 10
I Need tracing for passenger side 69-72 kidney pad Triumph 7
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
MadRiver New Clunking Noise from the Passenger Side Triumph 2
Tinkerman TR2/3/3A TR 3A Passenger Seat Tilt Forward Bolts Triumph 3
J BJ8 passenger foot well [LHD], right wall Austin Healey 1
S MGB Removing the passenger seat from my 71 MGB..... MG 4
T Wedge TR8 passenger floor - advice needed Triumph 7
Number_6 TR2/3/3A TR3A Passenger door Triumph 11
N TR6 TR6 Passenger door and window fit ? Triumph 5
TNMGB Rattle on rear passenger side MG 17
regularman Is there room under the passenger seat.... Spridgets 11
X Sagging passenger door MG 14
mabbott TR6 TR6 passenger side rear rattle/clunk? Triumph 11
Got_All_4 TR6 1969 Triumph TR6 passenger seat Triumph 13
B Passenger seat is derusted and primed!! Spridgets 3
M 87 XJ6 Driver and Passenger Footwell Water Leaks Jaguar 2
M USELESS PASSENGER SIDE BULLIT MIRROR FIX Triumph 21
msoylemez wiring harness on passenger side Spridgets 5
Musicman Installing Passenger Side Mirror Triumph 7
Johnny Occasional passenger, for the occasional 4 seater Austin Healey 4
