TR4/4A Hard Shifting TR4
joejoecat
When I first start to drive the TR4 it shifts very hard ( 1st and 2nd gear mostly),to the point I have to double clutch.After it runs and warms up it shifts "normal".It seems like it is getting worse.Any ideas?
DNK
Check the fluid.
I know, obvious question
1 MGB 1966 MGB hard shifting into 3rd MG 1
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
7 OD shifting hard! Triumph 6
F Hard Shifting Triumph 14
L T-Series Hard to start MG 11
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
E Spitfire '69 Spitfire hard top Triumph 2
T TR2/3/3A A type overdrive hard engagement Triumph 36
7 Top, hard Triumph 0
S TR2/3/3A TR3 Hard Starting Triumph 4
KVH TR4/4A Hard Start When Engine Hot Triumph 20
roscoe New / old hard top Austin Healey 16
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
B TR2/3/3A Hard Top Part Triumph 2
B TR2/3/3A TR3 Hard Top Triumph 2
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
Basil Spitfire Hard Top Seal Triumph 5
Madflyer MG B hard top MG Classifieds 0
Sopwith_Camel hard top bracket happy day Spridgets 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
K TR2/3/3A Hard start questions.... Triumph 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Lin Brake hard line question Austin Healey 4
A BN4 Hard Top Austin Healey 23
Healey Nut Good hard top on flea bay Austin Healey 6
W Spitfire Hard Top rubber Triumph 5
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
D General TR Hard lessons learned Triumph 4
Rut TR6 Hard top finisher Triumph 1
Rob Glasgow Hard Top Rubber Seal Austin Healey 3
TomMull Wanted TR3 Hard Top Triumph Classifieds 11
RAC68 Top Frame, Hard to Weld Austin Healey 13
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
2billydavies TR2/3/3A runs excellent but starts hard after use Triumph 8
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
D Hard Starting Austin Healey 14
aero3113 3000 with clear hard top?? Austin Healey 11
S This Austin Healey video had me laughing so hard I cried. Austin Healey 5
J For Sale Austin Healey Hard top Austin Healey Classifieds 1
D BJ8 pulls right on hard braking? Austin Healey 4
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
R winter hard starting BJ7 Austin Healey 16
B TR2/3/3A Tr3a brakes pull to left on hard braking Triumph 9
aero3113 100 hard top with windshield folded down. Austin Healey 4
S TR2/3/3A Linkage issue? Car stalls when braking hard Triumph 17
