bj7 hard shifting into 1st & 2nd gear
Roberte
Member
On my BJ7 I am having difficulty at random times in shifting into 1st and (or) second gear. I often have to shift through 3rd and 4th gear first before it will shift. It's as if the shift lever is locked out of those 2 (1st & 2nd) gears.
Any suggested causes?
Robert
Look to see if any of the lever retaining bolts have worked loose, or if the bushing at the bottom of the lever has been dislodged. My initial reaction__before reading the whole post__was that you were getting inadequate clutch travel, as if you're either low on fluid, or there's a problem with either/both the master and slave cylinder.
That's about the best I can do from here...
In a roundabout way, yes; the clutch is hydraulically actuated, so pushing on the pedal forces a piston into a (master cylinder's) bore, displacing the fluid. The displaced fluid, in turn, forces a piston out of the slave cylinder's bore, which acts upon the clutch lever. Moving the clutch lever, causing it to pivot inward decreases the clamping force of the pressure plate, allowing the clutch disc to spin freely, disengaging itself from the driven force of the flywheel/engine.
If for some reason, you're not getting enough travel of the clutch lever, then the clutch isn't fully disengaging, making it hard to shift into, or out of a gear.
That's one (1) possibility, but the nature of troubleshooting is to eliminate things that aren't contributing to a problem, until you get to the one that is.
Not so easy from here, but have to start somewhere...
R
Roberte
Member
Randy,
So is it your conclusion that the problem exists between the pedal and the slave cylinder as opposed to within the clutch itself?
Could the problem exist within the clutch itself, or within the transmission?
I do not get a grinding noise when attempting to engage 1st & 2nd gear they just seem blocked.
I recently installed a new slave cylinder, and fluid reservoir. Could improper bleeding of the lines create the situation?
Thanks for any assistance as I am not much of a mechanic and have very little money to spend on repairs through a shop.
Robert
I make NO CONCLUSIONS during online troubleshooting! How could anyone?
If the problem started happening after you replaced the slave cylinder, then yes, inadequate bleeding is the likely cause.
That's why it's beneficial__for anyone seeking help on a forum__to provide as much detail as possible, otherwise you're leading everyone (that's attempting to help you) on a wild goose chase.
TimK
Roberte;[COLOR=#333333 said:
itself?[/COLOR]
Robert
Uh, this makes owning a Healey a big problem. I have occasionally had the same symptom(blocked gear), but have a fully functioning clutch. It doesn't happen often, but letting the clutch in and out usually cures it, I think maybe the gear teeth are head-to-head or side-to-side and can't mesh. But clearly, Randy is the expert.
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
R winter hard starting BJ7 Austin Healey 16
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
A 1963 BJ7 - 6 months of hard work Austin Healey 12
JKent BJ7 clutch hard line Austin Healey 2
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
