Top Frame, Hard to Weld
RAC68
Hi All,
A good friend in our Healey group had acquired a 1966 Phase 2 BJ8 and is in the process of restoring much that the previous owner left undone. Recently, he redid the full interior and was in the process of refinishing the top frame before installing a new top and was having trouble re-aligning and installing the top frame. Thinking the cut and welded "S" section was original, he made many failed attempts to fit the frame for proper operation and window positioning and, in frustration, decided to recut and fit the joints.
After inspecting my original non-cut "S" frame section and realizing his welded unit was cut to compensate for new frame attachment platform position changes, he decided to recut the welded "S" section on the passenger side and re-weld to a position that would allow proper frame positioning. After establishing and securing the "S" section for good frame fit, the units was quick tacked and the frame removed for final welding.
This is where everything seemed to have gone wrong. Using a 120V MIG welder outputting 85 amps (20% duty cycle) set on its highest setting and slowest wire speed, every attempt resulted in a non-flowing buildup with slight or no real penetration of the frame metals. I understand the top frame is, and needs to be, constructed of strong steel and my MIG may not have the power to melt this metal. Having only used this unit on sheet metal and Home Depot angle iron, could my speculation be correct? Would a 120V Lincoln industrial MIG with an output of 140 amps be better suited for the task? Is there something I am missing?
Any suggestions would be appreciated.
Ray(64BJ8P1)
re: "... Using a 120V MIG welder outputting 85 amps (20% duty cycle) set on its highest setting and slowest wire speed, every attempt resulted in a non-flowing buildup with slight or no real penetration of the frame metals. ..."
I hope we have some 'real' welders on here who can answer, but here's my amateur's take:
This is counter to my experience; i.e. when you turn up the power you have to increase the wire feed speed to keep a good bead going (the greater heat burns the wire away faster). I too, have an under-powered MIG rig, and I've found that the wire must be as close to the metal as possible, without grounding out, to get the best penetration. I had trouble doing this as I'm nearsighted and wear contact lenses to get decent distance vision but, even with a magnifying lens in my welding helmet I couldn't see well enough to keep the wire close to the 'target.' Now, I don't put my contacts in if I'm going to be welding, and I can see the arc much better. I also lightened the shade of the helmet so I can see the arc and nearby metal; if the lens is too dark all you see is a bright white spot in a dark background. Of course, the sound of the process tells you a lot: sizzling bacon good, popcorn bad.
I haven't worked on any top frames, but I'm guessing it's tubular with 1/8" or less wall thickness; even a low-powered rig should be able to get a decent bead and penetration on this. My BJ8's emergency brake bracket has been broken for a long as I can remember; with the gearbox and OD out I took the opportunity to try to fix it by welding it back together. I was able to get a good, but short bead going and I think I got good penetration, and this is, I think, 1/8" plate welded to a chassis rail. I also did a rather poor repair on a cracked front suspension mount, but it's held for many years and miles. Not sure the exact nature of your repair, but if you're butt-welding tubing--or plate, for that matter--you should bevel both sides to get proper penetration. Also, you can preheat the area--a propane torch should do it--to get better penetration (this is why you 'stitch weld' on sheet metal, lest the preheating burn the metal away). 'Rhythm,' for lack of a better word, matters as well. Hold the arc in one spot too long and you get burn-through (sheet metal), or 'gobbing up' (thicker stuff) and if you go too fast you don't get enough penetration. Also, for a small, somewhat delicate repair like this a TIG rig would likely work better.
Side note: I've been interested in welding for quite a while, and I'm moving to a town with a community college with a welding program. I'm thinking seriously about enrolling once I get settled.
John Turney
I highly recommend it. I took a couple of community college classes on welding and it really helped.
RAC68
RAC68
Hi Bob an thanks for your response.
The "S" section of the top frame is a flat 1" wide by 1/4" thick piece of flat metal. It extends from the frame base mechanism up to the main section and supports the wood and weather stripping at the back of the window. As I understood, running slow wire allows the greatest amount of heat to be transferred where as running fast would transfer less heat. On metal panel welding, I would run at a medium setting with faster wire and brake the bead line frequently so as not to risk warping the panel.
I am also thinking of taking a Community College course to learn how to apply Cloisonné to restore my from badge. Having it done would cost around $300 and the course is less then $100 with an instructor helping me do it on my badge.
Thanks again,
Ray(64BJ8P1)
CLEAH
Ray, I think that is too small a welder to work with 1/4 inch plate. My 180 amp welder runs at 220 and has 10 wire speeds and 6 current settings. To weld 1/4 inch plate, my welder requires the wire speed to be set at 10 (max) and the current at 5 (next to max), as well as .035 wire. I don't think your friend's welder is up to this job.
RAC68
RAC68
Hugh,
First, thanks foryour response.
I totally agree that my MIG is probably under powered to handle 1/4" plate steel and without the power, no penetration.
To get max welding amperage to the metal, with corresponding penetration, I may have had my MIG wire speed set too slow. Since I had the wire speed set to a low number, I was not getting the maximum my MIG was able to deliver and overheating the feed wire splashing it.
Thanks again,
Ray(64BJ8P1)
bob hughes
We cut my soft top frame and re-welded it, the joint was Veed and a TIG welder was used.
I can get away with using my SIP 150 MIG welder just about on 1/4 metal, but the joint must be Veed and a bottom run put in first and then I weave in the rest, so far I have only used this method on my engine frame on wheels and a chassis support frame, I have not tried it out on the car.
:cheers:
Bob
Brinkerhoff
Typically you would increase the speed of the wire along with the amperage as you weld thicker steel. Too slow a wire speed and the wire can't transfer enough heat .
RAC68
RAC68
Bob/Brinkerhoff,
Thanks for your responses.
Bob, I like the idea of cutting a "V" to assist the penetration grab of the weld.
Brinkerhoff, Although I think my MIG and 35 wire used was too weak, I also believe I further aggravated the situation by having the feed set too slow causing the wire to flash and burn and not flow ... even for a tack.
Thanks all, when you do this so infrequently, I find I am always relearning until I get the feel again.
Ray(64BJ8P1)
bob hughes
Ray
Forgot to add, I always try a sample weld on scrap first to iron :playful: out the wrinkles. I have also used MIG on my brackets for the spot lights, just slightly under a 1/4 inch.
:cheers:
Bob
RAC68
RAC68
Thanks Bob,
I have welded 1/4" with my MIG a while back so I thought this would be the same. The Top Frame metal seems quite a bit harder then the Driving light brace I installed under the front pan that is braced on the bumper brackets. I had no welding that metal.
When you don't know what you don't know, you don't even know what to ask.
Thanks again,
Ray(64BJ8P1)
Keoke
Why not just take it to a welding shop and get it done????
I am sure that the top frame, bumper brackets and all the like on a Healey is all be classified as mild steel, and therefore no extreme measures required. You just need to fine-tune your settings.
My first MIG welder (a Silver Beauty, Italian produced machine__doubt it cost much more than $100.00 in 1986) was very limited in horsepower, and for a lot of the stuff I wanted to weld, I preheated it with my o/a torch; the metal flowed beautifully after that! It was just by dumb luck that I was also producing reduced stress weld as the result of pre/post heating, lol. I've made three (^3) upgrades since then, and as long as nothing seriously breaks on it, I expect my Millermatic 252 to be the last one I buy (it shares chores with a Miller Dynasty 200 TIG affair, and a Lenco Twin-Spot; also have a couple of devices for joining/welding plastics too).
RAC68
RAC68
Hi Randy,
You hit it on the Head. The MIG I am still using for most all I really need to weld is a Silver Beauty 90085 purchased in 1987 and used extensively. My first build was a Rotisserie and then addressed the rebuild of my Healey. It has performed well over the years and only gave me problems now. Maybe its old age that is hitting both of us (me and the welder).
Ray(64BJ8P1)
zoohow BN4 Top Frame Installation Austin Healey 1
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
JamesD BJ8 Top Frame Bumpers Austin Healey 12
C 100/6 BN4 Soft Top Frame Austin Healey 16
dbenichou289 TR2/3/3A top frame bracket Triumph 7
B Longbridge BN4 top frame question Austin Healey 6
P top frame fit Spridgets 5
RAC68 Top Frame platform location measurements Austin Healey 0
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
G TR4/4A Top Frame Paint Recs Triumph 12
warwick-steve BT7 soft top frame location Austin Healey 6
E Wanted WTB BT7 top frame Austin Healey Classifieds 3
I BJ8 soft top frame dimensions Austin Healey 4
C Top frame pinching soft top - BJ8 Austin Healey 6
aero3113 Wanted 100-4 Top and frame Austin Healey Classifieds 8
Rut TR4/4A TR4a or TR6 top frame? Triumph 4
TR3TR6 TR6 TR6 top frame windshield seal. Triumph 5
Marla TR4/4A Soft top frame Triumph 13
Rut Top frame and boot panels Spridgets 2
Lutz Kramer Top Frame Austin Healey 4
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
C TR4/4A TR4A top frame buffer Triumph 3
Rut Top frame storage brackets Spridgets 3
tomshobby New way to Install gasket between soft top and windscreen frame. Spridgets 2
B Top frame adjustment Austin Healey 6
Jeepster Folding top frame spring Austin Healey 12
G MGB mgb convertible top frame width MG 5
Jim_Gruber Brackets to hold top frame on a BE Spridgets 22
TR6oldtimer TR6 TR6 soft top frame not aligning with windows Triumph 1
Bob McElwee '66 BJ8 Phase III Top Frame Assembly Austin Healey 3
J TR2/3/3A Convertible Top Frame question for tR3 &3A Triumph 7
RJS Top Frame Repair - ideas needed Triumph 8
BJ8Healeys TR2/3/3A TR3A top frame straps Triumph 13
BJ8Healeys TR2/3/3A TR3A top frame color Triumph 11
Jeepster Folding soft top frame Austin Healey 7
S BN4 top frame needed Austin Healey 5
T Is this a Bugeye top frame? Spridgets 9
drooartz Is this normal -- top frame when folded MG 9
drooartz Sourcing snaps for folding top frame MG 9
F Spitfire Replacement Of Spitfire Convertible Top Frame Seal Triumph 6
Lotuswins Top Frame Powdercoat? Austin Healey 5
H TR4/4A Cover For Top Frame on TR4 Triumph 8
R Top frame question Spridgets 1
D Rag Top frame for 100-6 question Austin Healey 8
J BE top frame to borrow-Fla? Spridgets 10
B MGB Anyone need some MGB seats or top frame [free]? MG 2
J Bugeye single piece top frame same as two-piece? Spridgets 4
