Shifting a J2
Pizzi348
I was wondering what the correct technique is for shift a J2. It sounds like a bunch of marbles being mushed together each time I shift. I must be doing something wrong. Do I need to double-clucth through all the gears?
Thanks!
-Matt
Platinum
It'll help. A "stutter-shift" (out, pause, engage) works if the box is in good nick.
David_DuBois
Matt - you need to realize that you are using a non-syncrmesh gear box and learn how to shift it properly. DrEntropy's "stutter-shift works well for shifting up, but you will need to double clutch when shifting down. It takes some experimentation to find the correct speed vs rpm where the gears will slide into mesh without grinding, but once you get it down, you will find that you don't need to bother with the clutch other than when starting from a complete stop. It all works a lot better if you shift at a relatively low rpm (one can't hot rod this car with a non-syncromsh box in it). Once you get the process down pat, you will find it is a lot of fun to drive - I drove a 1936 PB from Washington state to Southern California many years ago and never had any problem with the gear box or with shifting it.
Cheers,
P
Pizzi348
What's the difference between a shutter shift and a double-clutch shift?
Are you saying of I match the RPM's correctly I can just move the lever without using the clutch?
Platinum
What they said. When upshifting use the disengage, pause, engage routine. I didn't think you were downshifting so didn't mention double-clutch. A double-clutch downshift is actually easier than upshifting once you know where the RPM match is (at least it is for me).
Bob Claffie
Trying to shift one of these old crocks without using the clutch is foolishness. Yes, it's "cute" to be able to do that but imagine the expense of rebuilding the transmission (or worse) while trying to master the art. They put three pedals in the car for as reason, besides starting from a dead stop, use them all. Bob
Deleted member 8987
Yeah, well........you get a feel for it. Not that you don't USE the clutch, but often you'll find yourself shifting with half the pedal.
Better to be double-clutching and looking than it is to just jam it into gear.
You ain't lived until you've street-raced a 1935 Ford, tached it out in first whil holding the gearshift knob (spring steel shaft) against the dash and just tapping the clutch pedal.....and you're in second with no steering for a few.....
Now, THAT gets expensive.
aeronca65t
Matt-
If I were you I'd contact someone in the Conn. MG club and see if there's anyone that can give you some hands-on advice about shifting your J2 (and maybe a demo).
I taught myself how to do this in a $20 Austin A40 many years ago, but I brutalized the trans in the process.
The internet is great and I know there's been lots of good advice above, but I think this is a subject that needs to be explained in-person. If you don't have any luck, I may know someone here in NJ that can help.
G'luck!
https://mgclub.homestead.com/
Platinum
True, dat!
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
AUSMHLY BJ8 Gear Shifting Austin Healey 5
L TR2/3/3A Shifting problems Triumph 4
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
M Grinding when shifting into first Spridgets 10
S TR2/3/3A shifting tower shifting rods on an early tr3 tower Triumph 11
S TR2/3/3A drilling out shifting tower for a dip stick Triumph 10
1 MGB 1966 MGB hard shifting into 3rd MG 1
Jim_Gruber Clunk in the rear when shifting Spridgets 26
K TR2/3/3A Shifting back from Reverse to First... Triumph 3
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
C Shifting problem? Triumph 15
F Missing pieces- centershift 3000- vague shifting Austin Healey 4
J Difficult Shifting Triumph 8
britndablood Side shift tranny with shifting issues Austin Healey 10
longbridgehealey gears grinding when shifting Spridgets 11
J TR4/4A Hard Shifting TR4 Triumph 2
B Down shifting problems, check my thinking? MG 1
stretchit2 Side Shifting Tri Carp Austin Healey 14
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
R difficulty shifting/downshifting-BJ-7 Austin Healey 7
jaegzie Close Tranny shifting pattern Spridgets 0
R 1500 gearbox, trouble shifting into first from neu Spridgets 20
thechileman TR4/4A TR4 Shifting problem Triumph 3
R trouble shifting, getting into gear &stuck in gear Spridgets 22
I TR6 tr6 shifting problems Triumph 12
eschneider T-Series Clutch - shifting problems - help? MG 19
Bruce_B Shifting Triumph 3
Jayrz Poor Shifting 2nd gear MG 5
K TR6 73 tr6 tranny shifting Triumph 1
M Shifting Issue: Clutch Question Spridgets 4
R electrical shock when shifting to overdrive Spridgets 20
zimmy my gearbox shifting and rebuild video Spridgets 4
P shifting gears Triumph 6
tahoe healey tough shifting Austin Healey 16
I TR6 TR6 not shifting into gear Triumph 3
sultanoswing T-Series Shifting Dipswitch from floor to column MG 3
S TR2/3/3A Tr3 shifting tower oil leak Triumph 3
J shifting Austin Healey 16
B Car revs upon shifting gears MG 5
7 OD shifting hard! Triumph 6
T Shifting in/out of overdrive MG 4
Steve P. strange smoothcase shifting problem solved.... Spridgets 1
Whytock Shifting Troubles MG 2
M Shifting Trouble Spridgets 17
F Hard Shifting Triumph 14
