Adjusting Spridget Doors
Jim_Gruber
Is there a simple how to guide to adjusting BE/Spridget Door Gaps. The PS on Bugsy was simple to do but the DS is giving me fits. Front Bottom of door is in 1/4" too far and I had lower hinge plate screw on door kicked to the left and out I think as far as it will go.
nomad
Something is probably bent and you may have to do some to get it right yourself.
Kurt
Spacer between the door and hinge?
Rut
Jim,
After looking at your door a bit I think you just have some reluctant screws and plates. I would loosen everything with the door open (how else?) and work it around a bit to make sure everything moves. I didn't see any damage, but there may be some parts that have become really good friends...break up that friendship with a little WP!
Rut
Jim_Gruber
Jim_Gruber
Rut,
Thanks for your input. Rut and his Wife Jo stopped by and met Bugsy IV on Tuesday. Rut was on a quest from Alabama to Washington Courthouse, OH, about 45 minutes away, to pick up a frame. Well he got the frame, suspension, engine, and tranny for his TR-4 Project and we got to spend a few minutes together. Unfortunately I didn't have time during a work from home day to buy him and his lovely bride lunch. Rut I owe you one. Really nice to put a face with a name I chat with on a regular basis. Played more with the door last night and getting it dialed in. This one was way off. I took it apart. got all of the hinges and tapping plates to loosen up as well as the striker plate and I'm real close now. Need to play with it a little bit more and then one to some more things on the punchlist. Like brakes that need rebleeding.
My potential buyer for Bugsy II is waffling. I cannot get OH to give me a Title for Bugsy II as I do not have a copy of the cars last Registration from 31 years ago. Paper copies of Registrations are no longer available from Canada and PO who had cancer is not returning any messages. I may be listing Bugsy II on E-Bay as a Bill of Sale Car only this weekend. Only other option is to file a claim in Common Pleas Court to ask a judge to issue an order to the state to grant me a title. A PITA. No clue how long that process would take. I need driveway space and don't want the car sitting outside under a tarp. This one is salvageable, tons of parts and all the new sheetmetal and a hardtop to go with it. No engine and tranny. Drop in your choice of engine and tranny and away you go.
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
AUSMHLY Adjusting Valve Clearance Austin Healey 31
S Testing and Adjusting procedure for RB340 Austin Healey 4
doc50 Adjusting play on steering box? Other British Cars 5
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
BN6_2197 Rookie question on adjusting valve clearance Austin Healey 9
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
vette Adjusting HD8 Carbs Austin Healey 21
M Adjusting Front Suspension Austin Healey 11
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
B Adjusting SU-HD6 Carbs Austin Healey 2
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
S TR2/3/3A little adjusting screw tr3 Triumph 1
F Adjusting gear lever, centershift 3000 Austin Healey 2
L Adjusting the bows before top installation Austin Healey 2
bighealeysource Adjusting toe in on a Healey Austin Healey 8
M Adjusting TR3 regulator Restoration & Tools 1
Scotsman Adjusting clutch pedal travel Triumph 2
R Adjusting Valve Clearances Triumph 13
Moseso TR2/3/3A Adjusting Koni shocks [TR3] Triumph 10
N Adjusting headlights on a BJ8 Austin Healey 2
A Adjusting BJ8 Doors Austin Healey 5
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
B TR2/3/3A 57 TR3 BONNET ADJUSTING SHIMS Triumph 4
drambuie Adjusting steering box with shims Austin Healey 6
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
M Adjusting idle speed Triumph 28
bighealeysource adjusting the handbrake on BN6 Austin Healey 1
TR6oldtimer Adjusting rockers Triumph 7
Darwin Adjusting steering play? Triumph 7
hondo402000 TR6 adjusting windows to Wind screen TR6 Triumph 2
T Adjusting valves makes me more crazy. Triumph 18
wangdango 100m bonnet fitting/adjusting?? Austin Healey 4
JohnnyMead Tips on Adjusting the Clutch Slave Pushrod? Triumph 4
pjsmetana Low Idle, DVG adjusting = no dice Triumph 12
pjsmetana Adjusting the Bonnet and the Bumper Triumph 5
DarwinT Adjusting a Weber carb Spridgets 3
bighealeysource ADJUSTING THE HAND BRAKE ON A BN1 Austin Healey 1
Y TR4/4A Adjusting valves on a TR-4 Triumph 4
