100m bonnet fitting/adjusting??
wangdango
HELP!
Just had my bonnet off in prep for the Vintage Festival at Lime Rock this upcoming weekend. And, now am having a fit re-fitting it. Any tricks, special techniques? I know I should have drilled some small holes thru the pivot points for alignment, but well, I didnt. Its just a matter of up, down, in, out......ughhhhhh
Now if you would've asked me <span style="font-style: italic">before</span> you took it off, I would've stressed the 1/8" holes trick.
The only thing I can suggest now, is Valium...
Is there any chance that the last setting is "scratched" into the paint (via the nuts, washers or bolts)?
dougie
Went through the same headache putting things back in order at the beginning of this race season, open, shut, open, shut, adjust, adjust. I was happy with it on the 5th or was in 6th time...............cold beer or red wine can't quite remember. You need to check out the racing form, I need another big Healey in the group. How about some pics. vids., and updates on your Lime Rock success. I'll do the same on our SOVREN Columbia River Classic. The AH Bonneville Cars from Australia will be on display before they leave for Utah.
We might have rain over Labor Day, this is last year.....................a little slick.
Cottontop
<span style="font-weight: bold">Any tricks, special techniques?</span>
Belleville washers....
Belleville washers are usually conical or "wave" spring washers that apply a gradual pressure as they are tightened under a nut/flat washer.
If you don't have any Bellevilles laying around, try inserting the bolt through the pivot arm and hood bracket as you normally would, then before you put on the nut, sandwich a garden hose washer between 2 fender washers.
Adjust the hood to pivot arm so that the hood is in maximum UP position and tighten the nut fairly tight.
Close the hood and firmly PUSH the hood down/back until it is in the correct position.
Then open the hood and, ONE AT A TIME, replace the fender washer sandwich with lock washers and torque the nuts..
I have not used this on my 100-6, but it has worked well on several other cars, especially my 65 & 66 Mustangs where aligning the hood is a nightmare involving not only the hood attach points, but engine bay mounted movable hinges.
Tim
MikeAH100M Treatment for Leather Bonnet Strap - 100M Austin Healey 9
Bob_Spidell New, and lively, 'discussion' on 'What is a 100M' Austin Healey 5
L The First "Factory" 100M Austin Healey 3
Editor_Reid For Sale 1956 Austin-Healey 100M [real one] Austin Healey Classifieds 0
bighealeysource Question on 100M front brake cylinder Austin Healey 4
lbcspinners Austin-Healey 100M auction on BaT! Austin Healey 36
HealeyRick 100M Brain Teaser Austin Healey 10
Healey Nut This one claims to be a real factory 100M Austin Healey 21
HealeyRick Earl's Court 100M on BaT Austin Healey 16
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
Healey Nut 100m Austin Healey 9
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Healey Nut Another 100M Austin Healey 9
W 100M that sold on Bring-a-Trailer aka BaT Austin Healey 13
S Anyone want a Honda 100M? Austin Healey 3
HealeyRick Earls Court 100M in Classic Motorsports Austin Healey 5
HealeyRick Earls Court 100M Austin Healey 9
Bob_Spidell Here we go again!: What is [and isn't] an Austin-Healey 100M? Austin Healey 3
R 100M For Sale RM Monterey Austin Healey 12
A 100M sold by Bonham's in Spa Francochamps Belgium yesterday Austin Healey 2
David Townsend Earls Court 100M Limited Edition Prints Austin Healey 0
bighealeysource Was 100M from Chasing Classic Cars sold this weekend? Austin Healey 20
David Townsend Gerry Coker Signature Now Available on 100M and 100S Collector's Edition Prints Austin Healey 3
H 100M on E-bay Austin Healey 37
David Townsend 100M Illustration Started Austin Healey 32
HealeyRick Another 100M Story Austin Healey 23
magman 100M etched carburettor numbers Austin Healey 4
bighealeysource Number of 100M's registered in 100M Registry Austin Healey 1
Editor_Reid The 100M & the Le Mans Kit & all that rot Austin Healey 37
HealeyRick 100M at The Quail Austin Healey 3
M Original Owner Factory 100M Austin Healey 31
A 100M or not ? Austin Healey 37
AUSMHLY For sale, 100m Austin Healey 31
J 100M Shift Boot Austin Healey 0
MikeAH100M Car Research - 56 100M Austin Healey 5
DerekJ Dealer 100M Austin Healey 16
R Earls Court 100M Sold Austin Healey 19
CLEAH What is a "Dealer 100M LeMans?" Austin Healey 32
MikeAH100M 100M Timing Austin Healey 3
HealeyRick Salad Days for the 100M Austin Healey 7
L 100M Carbs Austin Healey 1
MarshgrassA Another Dealer 100M question Austin Healey 13
bighealeysource Anyone know of a source for correct size "M" for 100M models ? Austin Healey 0
HealeyRick 100M at MM Austin Healey 14
H 100M "Dealer" on e-bay Austin Healey 3
Bob_Spidell Another "100M" ? Austin Healey 23
Editor_Reid 100M Introduction Austin Healey 9
V 100M detailed engine data Austin Healey 3
bighealeysource Craziness continues with 100M pricing Austin Healey 15
bighealeysource Best plug for BN2/100M Austin Healey 3
