Throttle shaft bearing/bush on bulkhead
warwick-steve
Hi
I have a tricarb BT7 which has a throttle shaft rotating in a "countershaft support" and supported in a bearing/bush on the bulkhead.
Does this end bearing/bush need lubrication?
Can the bush be easily replaced?
Thanks in advance for our help
Steve
Healey Nut
The bulkhead bearing for the throttle shaft is a rubber grommet with a bronze/brass machined bushing bonded to the rubber in the centre . It shouldnt need lubrication but some dry lubricant may help . Its easily replaced , make sure the metal frame that supports it is not bent as that will mean the centre bushing isnt lined up correctly with the shaft and cause binding .
John Turney
The difficulty in replacing the bulkhead bearing is that it's usually the rubber grommet that perishes. It is too easy to end up with the grommet being pushed into the horizontal heater duct, which is difficult to access without removing the heater.
steveg
The BJ7 & BJ8 solved this by mounting a bracket on the firewall, into which the same grommet/bearing goes. It would probably be simple to install this bracket, along with a plug for the hole in the firewall.
warwick-steve
warwick-steve
Hi
I just looked at the assembly. There is a bracket mounted on the firewall by two screws into which the grommet /bearing is fitted. (There is a rubber plug in the firewall about 4cm directly below the bracket.)
I presume to fit a new grommet/bearing it is necessary to undo the linkages and slide the shaft forward to allow the grommet/bearing to be slid onto the end and then located into the bracket.
Sorry but I don't understand how the grommet could be pushed into the horizontal heater duct, maybe I have the bracket that steveg mentions.
thanks again
Steve
Healey Nut
Mines a BJ8 but its probably similar .
Take off the carb linkage and push out the bushing .
John Turney
Hi
thanks again
Steve
Sounds like you have the bracket that Steve mentions. I have a BN4 where the grommet is in the firewall, and no bracket.
steveg
Hi
thanks again
Steve
Steve - if you have the bracket per picture below, you should be able to remove the screws at 9 and 3 o'clock and swivel your rear throttle rod enough to slide the bracket with bearing off toward the firewall. There is no clip holding it on.
When you have the bracket on the bench, insert the bearing grommet there.
I used to have the bearing in the firewall per John T above (plug to LR of bracket), but added the BJ8 bracket when I added my HD8 carbs.
warwick-steve
warwick-steve
Hi Steve
There is very little access close to the bracket on the tricarb set up. From what I can see, there is just about enough room to replace the grommet as follows.
- unscrew bracket/grommet and slide forward on shaft as far as possible
- push out grommet to rear and slide off shaft.
- push in new grommet from rear side of bracket
- slide bracket back into position and screw up.
To have to dismantle the shaft and linkages would be a real pain so would hope the above procedure works out.
From closer inspection the rubber grommet looks in reasonable condition so will delay changing until absolutely necessary.
Thanks to all for your advice
Steve
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
J TR2/3/3A Need a part for the throttle shaft. Triumph 4
B Pics of throttle shaft reaming Austin Healey 6
C TR6 Broken Throttle Shaft Triumph 4
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
E TR4/4A TR4 Throttle shaft position Triumph 1
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
A SU throttle shaft and bush dilemma - advice? Triumph 41
glemon Rebuilding stromberg Carbs Throttle Shaft Bushings Triumph 6
M Throttle shaft problem!! Austin Healey 5
M_Pied_Lourd TR2/3/3A TR3A Throttle Shaft Bushings Triumph 15
J Test for wobbly throttle shaft? Triumph 9
luke44 TR2/3/3A TR3 - Re-assembly of Throttle Shaft Triumph 8
R SU Throttle shaft Bushings MG 22
T ZS throttle shaft - how to determine excess wear Triumph 15
eschneider anyone have a throttle shaft reamer for sale? Restoration & Tools 6
F TR2/3/3A TR3 Carb Throttle shaft Triumph 10
tomshobby throttle shaft bushings Triumph 15
Harry_Ward TR2/3/3A TR3A throttle shaft bearings Triumph 23
Brosky TR6 Replacement throttle shaft bushings for TR6 Triumph 24
John Loftus throttle shaft bushings Austin Healey 12
Lin Freeing throttle shaft levers Austin Healey 11
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
S Overdrive Throttle Switch Austin Healey 4
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 31
Walter74 Throttle Cable Conversion Austin Healey 6
J Throttle Controls Identification Austin Healey 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
C Jammed Throttle Linkage Austin Healey 3
R TR2/3/3A Throttle rod spring location Triumph 3
T BT7 throttle relay levers short and long Austin Healey 2
R TR2/3/3A Carb throttle return spring tension Triumph 2
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
D TR4/4A SU HS6 throttle spindle size Triumph 20
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Lukens TR2/3/3A Installing a throttle. Triumph 2
K TR2/3/3A Kangarooing on light throttle Triumph 14
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
