Front Brakes...
rjfoster03
Member
Not totally experienced with working on cars, I am replacing the front pads on a 66' Sprite.
I purchased new pads, attempted to put them on, but found the pads would not fit due to not have enough clearance (I did compress the cylinders as much as I could). I had contemplated on having the rotors turned anyways, so I went ahead and had them turned.
I cleaned the turned rotors prior to putting them back on. Everything fit in perfectly as it should. No looseness anywhere, bearings are new, etc... I am using semi-metallic pads that are anti-squeal, but added some anti-squeal "lubricant" where it should be added.
So, the brakes work very well, but boy do the let out a SQUEAL!
Any helpful hints on how to get rid of the horrible noise? I have read that squeal is from vibration, but with everything as it is set up, I should not have that much vibration.
Would it be best to try an anti-squeal strip set between the pads and the piston?
Should I replace the rotors and then buy new pads as well?
Any help is greatly appreciated.
mightymidget
From what I understand mother goverment is protecting us from certain materials that were used in the manufacture of brake linings/pads. so now they are prone to squeal from the reformulated materials used in brake products.
I just traded a Scion X-B because a shop could not get rid of the squeal, and refuse to drive a car whose brakes squeal. This may or may not be the problem. but if you turned the rotors (even if new) and installed new pads. Sounds like your only choice is trying your luck with a different brand of pads
Mine squealed at first, but then I went and performed several "hot stops", and they eventually settled in and quit squealing.
livinginthepast
I've always found that they wear-in and the squeal goes away after a little driving.
Platinum
"Decisive" use of the brakes should alleviate the squeal temporarily... try a different compound pad, or get some Permatex spray-on "Anti-Squeal" compound and treat the existing pads.
You can try sanding the pad material with some #180 sandpaper to knock down any glaze before reinstall.
bgbassplyr
Here's the trick.
Pull the pads and bevel the leading edge (bottom) of each puck with a grinding wheel or a bastard file to eliminate the hard edge of the puck where it interfaces with the disk. Squeal is caused by the puck vibrating against the disk, much like finger nails on a black board. The bevel should eliminate the problem.
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
K TR2/3/3A Sticking front brakes? Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
John_Mc TR6 Front brakes won't release Triumph 20
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C 100-6 front drum brakes? Austin Healey 36
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
P Front drum brakes - fluid lines Austin Healey 12
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
trrdster2000 Post-War Other Front brakes on the Roadster Triumph 5
R BJ8 Front Brakes drag some Austin Healey 9
T TR2/3/3A TR3A front brakes Triumph 2
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
M Stuck front brakes? Spridgets 8
M Front brakes are sticking Spridgets 33
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
coj 1960 Healey 3000 front and rear brakes Austin Healey 2
bighealeysource front disc brakes conversion for 100-4 Austin Healey 21
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Stewart Dragging front brakes MG 7
B front disc brakes- 66 sprite Spridgets 8
RickB Front brakes seizing - what's with that? Spridgets 23
M Slight bind in front brakes Spridgets 7
sparkydave Dragging front brakes Spridgets 4
T Check list to convert to front disc brakes Spridgets 9
T Front disc brakes make a big difference? Spridgets 5
T Time to redo all my brakes and front suspension... Triumph 14
S TR2/3/3A tr3 front brakes hoses Triumph 9
drooartz Installing front suspension/brakes - review Spridgets 1
zschicago my first Healey and questions about front brakes Austin Healey 10
v8mgbal front brakes Spridgets 9
M Difference between MK IX and XK 150 Front Brakes? Jaguar 6
Brosky Front Suspension & Brakes -Done Triumph 5
N TR6 Clip wires on front brakes for TR6 Triumph 9
eejay56 BMW 320i front brakes locked up Other Cars 8
1 front brakes Spridgets 3
19_again leak front brakes MG 6
M front brakes Spridgets 12
M front brakes Austin Healey 3
jmwuva05 Front drum brakes. Spridgets 2
ncbugeye Front wheels won't spin, dsic brakes binding? Spridgets 13
zimmy front disk brakes Spridgets 9
T TR4/4A Early TR4 - Front Brakes Triumph 3
zimmy front brakes and calipers Spridgets 3
R TR6 TR6 front brakes Jack Drew Triumph 13
