19_again
I just took the B out for a quick check after some exhaust clamp tightening and my brake pedal went slowly to the floor. Back in garage I see Brake fluid around the outside of right fronttire. Checking the lines at the wheel can't see leaks at the connections, not a good thing. As the boss presses her foot to the floor, fluid starts dripping from the bottom of the brake housing, it seems that an inner seal has let go. At IMHO, any other ideas? I was really hoping I would be working on it rather than driving it on the fourth, NOT. May need to add to that order Tony!
Is it even financially logical to repair the seals etc or should I just replace the caliper assy?
Thanks,
Mike
Thanks,
Mike
