RobT
Like most Triumphs I have known, my TR250 has an oil leak at the front of the block. Since I have the radiator out for a re-core, and am overhauling the front suspension over the winter, I am thinking of attacking the oil leak too.
Now it looks like the best approach will be to pull off the timing chain cover, front plate, and sump, and then replace all the gaskets and the crank seal. I also have a steel replacement of the aluminium saddle block that goes under the crank and ties in the front plate and sump. Using the steel unit is supposed to allow you to get greater torque and so a better seal on the sump and front plate at this point.
Does anyone know if replacing this and all the seals etc is possible with the motor in-situ, or am I likely just to make things worse by not being able to properly fit everything without having the motor out? Anything I should remember or good tips to making the front end leak-free?
Thanks,
Rob.
Thanks,
Rob.
