Can there be any other reason for gas to leak out of the front carb other than the float and needle valve? I have a 1969 TR6 which when I brought it home and parked it nose first on my sloped driveway gas was pouring out of the front carb. Off they came and I got the Zenith service kits and a different pair of carbs from a 71 and replaced all the jets, gaskets,O rings etc set the float valve to the correct setting and put them on the car. It fired up first time and though rough was tunable. Well you've guessed it the gas is leaking from the front carb again so I retightened all the screws but to no avail. Can there be something else that is causing this as it seems strange that the same thing has happened with separate carbs
