TR6 TR6 Gas Cap Spring Tech Tip
houleyh
I need to replace the spring/latch assembly of the gas cap after rechroming? Can't remember how it was installed before. Does anyone have a tip or advice to reassemble the gas cap latch?
Thanks
Y Houle
T
Tinster
Ask and yee
shall receive.
The tension spring is loaded onto the
gas cap release lever dowel bar. One half
twist of the spring should do it. The spring
has small stright ends that provide the grip
to the release lever and the cap itself.
You will need 2 hands and an ice pick held
between your teeth to get these 3 pieces into
position.
OR- super glue the release lever and velcro
the cap to the tank opening edges.
Hope the photo helps. Tinster
H
houleyh
Easy solution. I put the spring in place and held it with a small pin (chopped rivet shaft) then put the lever & spring in place.
Sliding the spring pin in place moved the rivet shaft out.
easy Job
YH
I TR6 What glue for TR6 magnet in gas cap? Triumph 9
I TR6 TR6 gas cap help Triumph 2
Paulus TR6 Gas cap fitting on TR6 [71] Triumph 8
BierRunner TR6 TR6 Gas Pedal Triumph 4
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
B TR6 76 TR6 gas separation tank - orientation? Triumph 2
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
M TR6 TR6 Gas Leak From Front Carb Triumph 5
BobbyD TR6 TR6 Custom Aluminum Gas Tank ~ 15 Gallons Triumph 1
BobbyD TR6 TR4 & TR6 Gas Tanks Triumph 6
I TR6 75 TR6 rubber gas lines Triumph 6
I TR6 TR6 gas line leak - please help Triumph 15
T TR6 TR4a and TR6 gas tanks interchangeable? Triumph 10
hondo402000 TR6 TR6 Gas tank Sealing Triumph 5
hondo402000 TR6 Paint continues now the TR6 gas tank Triumph 9
B TR6 TR6 gas gauge stopped working Triumph 10
R TR6 TR6 Gas Tank Outlet Gas Tank to Body Seal Donut Triumph 6
TR6oldtimer TR6 Central Coast Calif gas and ping in a TR6 Triumph 2
mrv8q TR6 TR6 gas tank removal Triumph 13
I TR6 69 TR6 gas tank/emissions Triumph 10
B TR6 Draining gas tank and lines TR6 Triumph 3
I TR6 TR6 gas gauge not reading correctly Triumph 11
bobh TR6 TR6 Gas Pedal Shaft Bushing Install Triumph 16
teeslounge TR6 TR6 Sputter and Gas Triumph 8
S TR6 What were the manufacturer's estimates on gas mileage for a TR6 Triumph 4
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
