Frustrating Intermittent Problem
Dadandson
My 74 Midget 1275 runs great, most of the time. I 'll be mototring along and all of the sudden the motor just quits! The red ignition light comes on and it is as if someone turn the key off. I pull over, wait 1 minute, start her up and everything is fine. This happens with no frequency or regularity. I also notice the ignition light glowing, not on, sometimes during idle. Has anyone seen this? It may be a common problem for you guys but I am a novice.
65sprite
I had a similar problem several years ago with a vw. Same symptoms. Turned out to be a bad coil. Easy enough to test by substituting the coil, and see if the problem persists, if you have a spare. Or, this may be one of those things Checker or Autozone can test in the car. I know they do batteries and alternators, not sure about coils.
As I recall, the failed coil would get Very Hot. May also be an indicator if that's the problem.
Dadandson
Dadandson
Thanks. I will have the coil tested. Another friend of mine suggested that there may be a loose wire. My son and I have been doing quite a bit of work under the hood lately and maybe something came loose or was not re-attached properly.
jlaird
Bad coil, bad condenser or loose wire.
I had a similar problem, and it turned out to be the hot wire feeding the coil. It looked good, but was broken up in the insulation. It made connection when the insulation was cold and stiff, but when it became warm and pliable it lost connection. But as mentioned... it could be a lot of different things.
Bugeye58
Check the low tension lead inside the distributor, too. I've seen these fail causing the same symptoms.
I've been driving my '72 with a low grade ignition light for five or six years. Not a charging problem, just a crappy lamp circuit.
Jeff
kcbugeye1275
When I first started driving my BE about 25 yrs ago I had a problem that would only strike on the hottest days, once every several yrs. Yrs later I found the ground to the electric fuel pump was almost not connected. These problems can be hard to resolve.
Sarastro
This kind of problem just about has to be something electrical. Start the car, tug on wires, twist the harness, tap on the coil with the handle of a hammer, wiggle the ignition secondary conductors, jiggle the ignition key. You can even use a hairdryer to heat up things like the coil, which might be going open at some elevated temperature.
In my Bugeye, the guy who did the restoration used the wrong screw-in cap on the coil. This left the secondary wire loose, and occasionally I'd get spells of really bad running because of it. I suppose it could have killed the engine, too, if the situation were a little worse.
It's also easy to bump the ignition key, as I've discovered, on a shift into third, and the car shuts down really fast when I do that. First time it happened, I had no idea why it stalled.
By the way, don't automatically assume it's something mysterious. A lot of these problems are simple, and if you decide at the outset it's gonna be a difficult fix, it will be. You'll probably kick yourself when you find it. I know from experience, and my well dented tush bears witness.
In short, there are an unlimited number of things that can do this. But almost all are electrical.
Dadandson
Dadandson
Resolved! The small plastic or ceramic disk on the ignition switch had worked its way loose. I held it in and my son, using a screwdriver and a small hammer, was able to re-crimp the disk in place. Saved $100! Runs like a champ. Thanks to everyone for your help and support.
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
Johnny Frustrating new Healey problems? Austin Healey 9
dklawson Spitfire Frustrating Spitfire Weekend - Progress My Foot Triumph 6
Trevor Jessie Today's frustrating goof... Spridgets 12
rick_ingram Frustrating day..... MG 4
jlaird So frustrating Spridgets 3
fmichaels frustrating reproductions Spridgets 13
TRclassic3 Man this is frustrating! Triumph 20
M Spitfire Frustrating Spitfire tailight problem Triumph 3
rick_ingram Frustrating Day with HS6 carbs MG 6
M An ever increasingly frustrating problem MG 4
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
Griz Intermittent Misfire Austin Healey 33
S Intermittent operation of tachometer Austin Healey 9
Jim_Gruber Intermittent Horn Spridgets 2
T intermittent deflating tyre Austin Healey 6
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
doughairfield TR4/4A Intermittent vibration at 3000 RPM Triumph 2
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
AUSMHLY intermittent right blinker Austin Healey 14
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
Michael Oritt Intermittent short Austin Healey 14
R Intermittent starter Austin Healey 8
G Intermittent flasher [the TR that is] Triumph 8
nevets Intermittent sputtering Austin Healey 38
Shinsen774 Intermittent Stumble - Diagnosis? MG 7
R BJ8 overdrive intermittent Austin Healey 11
roscoe Intermittent weirdness Austin Healey 20
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
athenssprite tach is intermittent Spridgets 5
healeyboz Intermittent problem finally fixed Spridgets 6
19_again intermittent power loss MG 0
Baz Intermittent miss? Spridgets 24
AUSMHLY Got intermittent wipers? Austin Healey 2
gsalt57tr3 Intermittent Start problem Triumph 1
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
M Intermittent Cooling Fans -'78 B MG 5
M Intermittent Wipers [the bad kind] MG 3
RobSelina Intermittent turn signals.... Spridgets 6
MGTF1250Dave Intermittent Electric Faults MG 9
M Intermittent starting problem Jaguar 1
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
G windscreen problem Spridgets 1
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
J TR6 72 TR6 starter problem Triumph 10
