Intermittent Wipers [the bad kind]
Midgey
Member
Folks, my 74 Midget has been toying with me. The wipers work when it is dry, and when the rain starts. But, they stop working when the rain gets pretty strong. Fan also stops. This is a little bit inconvenient. I am about to replace the seal between the windshield and the cowl, because I notice moisture on the metal just inside the windshield during the heavy rain. I am thinking that maybe the moisture might be going behind the dash, dripping down and shorting the wiper and fan switch wires. Do you think that getting the new seal squared away will solve this? Or are there any other ideas about the wiper problem?
PS, we are generally unfamiliar with rain in Albuquerque /ubbthreads/images/graemlins/nopity.gif.
Bugeye58
Midgey, first let me welcome you here. Hopefully you will enjoy it as much as I.
Your idea regarding the windscreen frame/cowl seal is a good one. I have had the same thing happen to me, and the new frame seal fixed it. I was actually having water drip on my leg!
One other thing to check is the grommet where the wires come through the firewall. There could be some minor chafing there that would cause the problem.
You may be unfamilar with rain in ABQ, but from what I remember, when it did rain, it poured!
Good luck,
Jeff
[ QUOTE ]
[/ QUOTE ]
i know about that, but have never had an electrical issue due to that.....yet. My seal is also new.
Midgey, Welcome to the bestBritish Car forum on the web. Great place to learn.
Mark /ubbthreads/images/graemlins/driving.gif
Bugeye58
Midgey, I should also have mentioned checking the connections at both the wiper motor and the blower motor. Sometimes I get ahead of myself and take things for granted.
The one where I had the seal issue was a '63, with totally different switches. I would bet it is more of a connection issue on the '74.
Jeff
AUSMHLY Got intermittent wipers? Austin Healey 2
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
Griz Intermittent Misfire Austin Healey 33
S Intermittent operation of tachometer Austin Healey 9
Jim_Gruber Intermittent Horn Spridgets 2
T intermittent deflating tyre Austin Healey 6
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
doughairfield TR4/4A Intermittent vibration at 3000 RPM Triumph 2
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
AUSMHLY intermittent right blinker Austin Healey 14
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
Michael Oritt Intermittent short Austin Healey 14
R Intermittent starter Austin Healey 8
G Intermittent flasher [the TR that is] Triumph 8
nevets Intermittent sputtering Austin Healey 38
Shinsen774 Intermittent Stumble - Diagnosis? MG 7
R BJ8 overdrive intermittent Austin Healey 11
roscoe Intermittent weirdness Austin Healey 20
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
athenssprite tach is intermittent Spridgets 5
healeyboz Intermittent problem finally fixed Spridgets 6
19_again intermittent power loss MG 0
Baz Intermittent miss? Spridgets 24
Dadandson Frustrating Intermittent Problem Spridgets 8
gsalt57tr3 Intermittent Start problem Triumph 1
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
M Intermittent Cooling Fans -'78 B MG 5
RobSelina Intermittent turn signals.... Spridgets 6
MGTF1250Dave Intermittent Electric Faults MG 9
M Intermittent starting problem Jaguar 1
M Windscreen Wipers Parking Spridgets 4
R Mounting wipers Austin Healey 8
J Windshiel wipers Austin Healey 13
J Windshiel wipers Austin Healey 3
P Bugeye Windshield Wipers Spridgets 7
HealeyRick Wipers Won't Stop Spridgets 6
K TR2/3/3A Windshield wipers again..... Triumph 8
rjc157 Windshield Wipers Austin Healey 0
L TR6 No power/not enough power to turn signals, wipers Triumph 8
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
Crankshaft TR2/3/3A Loss of power to wipers ad turn signals? Triumph 11
B How do wipers mount to scuttle top on a 100-6? Austin Healey 16
rjc157 wipers Austin Healey 4
D Wipers Restored Spridgets 6
Newkie MGB MGB wipers MG 8
S TR2/3/3A windshield wipers tr3 Triumph 1
doates Windshield Wipers Triumph 2
