Man this is frustrating!
TRclassic3
As those know that have read my previous posts, this all started with an attempt to get my idle under control (idle at 1400) I fooled around one day, didn't real change anything that I was aware of, but did not correct the idle and did manage to make the car idle very rough, backfiring from as exhaust an through carb. So today I attacked the problem. Most felt that it was timing related. I have adjusted the timeing multiple times using different methods, the most recent being static timing using a Color Tune. I have also cleaned the carbs, centered the jets, used various methods to try to dial in the carbs, all with little success. I was able to somewhat improve on the smoothness of the idle, although still a bit irregular, and also able to rev the engine in the garage without back firing. However, when I take it out on the road it will backfire again and run like crap under acceleration. I've also changed the rotor and cap. Reminder that I am running Pertronix ignitor.
I don't seem to be able to get one of the carbs leaned out corretly. The piston falls with a nice loud click, but according to the color tune, even with the jet all the way up it's still rich. Interestingly , if i do the test and lift the piston slightly it essentially stays the same, slight increase, but little enough that it wouldn't seem to be the problem. Plugs are well carboned though.
I really have no idea where to go from here. Is it possible that the pertronix is the problem? I feel like I'm fishing here.
Andrew Mace
I don't understand how any electronic ignition could cause such a problem as a high idle, at least not by itself. Certainly timing is one possibility for a cause, but I don't see how the electronic ignition could "override" the timing, i.e., the physical position of the distributor?
TRclassic3
TRclassic3
The pertronix is not new. It was in it when I got the car a year ago. I would guess that it has 3 to 4 K miles on it.
TRclassic3
TRclassic3
Ithink you are right Andy. I jsut don't know what I should be focusing on., Carboration, timing, ignition....???
Andrew Mace
Ed, just curious: are you using the original tachometer to judge that 1400 rpm idle? If so, have you checked it against anything such as an electronic instrument (i.e., diagnostic equipment)? Just thinking that maybe your tach is a bit psychotic. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
PeterK
Ed - do you have points setup you can install and try? I can send one out if you need to borrow it to diagnose the problem. Or just buy point and condenser set.
I thought about the marks on your pulley and the reason they are off is probably because someone took the pulley apart and didn't put it back in the same holes. There are six 1/4-28 bolts that hold the two pulley halfs to the front hub. The drilled hole should line up opposite the keyway so that it points to 12 o'clock at tdc. Easy to put it together wrong. So someone just made their own marks instead of taking the pulley apart.
Got_All_4
Sounds like my 60 TR3A. Idle and richness has been a problem for years now. I even foul out plugs and have done everything you've done. I know where the problem is now with the idle. My throttle shafts are worn out. Air that gets sucked in through the gap between the carb body and the shaft. This leans out the mixture and increases the idle. I'd try this test, Get a can of brake cleaner or starting fluid with the extension straw and spray some around the throttle shaft outlets while the engine is running. If the RPMs rise you know the problem. If not, or you may want to do this any way, spray around the intake gaskets and listen to the RPMs. Any increase then that's your problem. You must address this problem first even if the carbs have been recently rebuilt to rectify ANY mixture problems. Bushings can be but in. I've heard of guys counter boring the shaft holes and pressing in shaft seals like on Stromberg carbs. Good luck and be carful when you are spraying. You have that hot exhaust manifold under the carbs.
TRclassic3
TRclassic3
Thanks for the responses. Andy, I am just using the car tach to measure the idle. At this point I would be happy to just get things back the way the were. Even though the idle was high it at least didn't miss and backfire. The way it is now it isn't driveable.
Peter, I do have multiptle sets of new points and condenser(thanks for the offer). I could switch over to check the results. Should I assume from your suggestion that you believe the problem to be ingnition and not timing or carboration? Just had anoter thought. One of the things I had done juest previous to this problem was to pull the plugs, clean and gap to .025. Could this have cause the problem. Geez could it be as simple as plugs?
TR3ATR250, I have cehcked for leaks by spraying the carbs and intake with carb cleaner. No indication of leakage. If it were would the result be lean runnig rather than rich?
again, thanks to all for the help.
PeterK
No idea what the true problems is, just trying to isolate the problem and go from there. When I make a change that doesn't fix the problem, I most always put it back to the state before the change to not introduce another problem.
Since your problem occurred after you poked around inside the distributor with your meter, I would start looking there. Maybe pull the Pertronix and points plate, examine the wires for shorts, cap, etc. Make sure the points plate is rotating properly ...
GOOD LUCK for a fix TODAY!!!
Twosheds
Did you drop a plug on the floor when cleaning and gapping?
Twosheds
I'm like PeterK, then. Maybe you knocked something loose with your meter probe.
The only thing I can think of is going back to points. You could swap out the plugs if you have any spares.
I'm just grabbing at straws now.
TRclassic3
TRclassic3
Grasping at straws is what I've been doing for 2 days. Swapped out the plugs. Still running rough. Centered jet on front carb. No change. I guess i'm down to swapping in the points, although I cannot imagine what I could have done. There isn't much there, and I made no adjustment. Does seem like the only thing left.
Twosheds
The problem might not have anything to do with what you did. Sometimes things will fail at the moment you change something, making you think that the problem was caused by the thing you changed, but the failure is really unrelated.
It's just the inanimate objects' way of being onry.
The Boffins here at HSTRL Soggy Bottom have experimented with this phenomenon.
Got_All_4
Correct, it would lean it out on the idle side. That's why the RPMs go up. The air is introduced after the metering needle so when you try to adjust the mixture you have to richen it to compensate for the extra air. As the shaft floats around in the carb body it will from time to time shut off the leaking air making the mixture way to rich. I've forgotten all that happens on the higher rpm ranges and I know I have an article around here explain it. But I'll never find it when I need to. We recently moved and can't find anything now. Keep this posted and on the first page and maybe change the title to define your problem more closely and you'll find someone who will get you the right answer. Larry
prb51
I'd suspect the carbs as the culprit. Everytime I've had a similar issue with fluctuating idle/rich/lean problems(solex's, su's etc) it has been throtle shaft issues allowing air to seep past at different rotation intervals.
Luckily SU's are inexpensive to rebuild.
Got_All_4
A quick way to check if it's the carbs is while driving and the engine at full temp pull the choke and see if there is any differance in pefromance.
toysrrus
Good Morning & or Hopefully It will be for Yourself?
I`m not a Guru @ setting the Carbs at all but Sounds like you may have a "Vacuum Leak" somewhere: Using some "Ether" or "Carb Cleaner" spray Everywhere! The Carb Shafts being out of Alignment or slightly bent is a Typ Problem: Spray the Exhaust Manifold; Spray everything that has a "Gasket" attached to It! Should this Not show a Vacuum Leak; Call the "GHOSTBUSTERS"!! There is an Exc. Carb Re-Builder in LI NY: "JOE CURTO", whom I`m sure your probably familiar with? He advertises Everywhere, Hemmings etc etc: What you may also do is contact My "Brit Mech": He`s Outstanding & Extremely Helpful: He`s a Tech writer for "Moss Motors": His Ph. # is: 570-424-6379; His Name is "Don Lawson"; Ref. Myself, "Russ Chura": He`s Located in NE PA:
Good Luck & Don`t Quit; There is a Solution;
Regards, Russ
BoyRacer "...For The Man In Command" Austin Healey 5
drambuie Meeting up with Gemini man on Route 66 Austin Healey 0
PC respect the van, man. Spotted 3
HealeyDave Isle of Man TT Races 2014 British Motorbikes 4
Boggsy64 MGB John Twist is the man! MG 1
G Man oh man.. Spridgets 5
aeronca65t "Iron Man" Morgan-racer passes Racing 3
D Invisable man Austin Healey 3
KVH Griot's One Man Bleeder Kit Triumph 6
JPSmit Oh man do I want this car Other Cars 15
Boink Man recovers stolen Healey after 42 years! Austin Healey 36
Basil BMW Z8 Enough to make a grown man cry Spotted 3
T OT - Interesting moment at Isle of Man TT Triumph 6
drambuie It's enough to make a grown man weep Austin Healey 17
TulsaFred Tips for an amateur body man Spridgets 29
Gordon_Dedrick Handy Man Triumph 11
JPSmit Man could I see this in a Midget! Spridgets 13
KVH Griot One Man Brake Bleeder Triumph 8
B Country man painted today! British Motor Corp 1
JPSmit Oh Man, now I really need that lottery win Spridgets 5
AngliaGT aroostok = The Man! MG 1
T Guys - contact me before bidding on Tr-man items Triumph 13
aeronca65t Isle of Man TT vid British Motorbikes 2
dougie Man Handling A Big Healey Racing 4
dougie Isle of Man TT Racing 0
angelfj1 TR2/3/3A Handy Man TR3A Triumph 8
19_again Man oh man, what a set!! Triumph 0
T Wedge TR8 is back from surgey - oh man is it fast Triumph 12
nevets Movie Healey sighting - O' Lucky Man Austin Healey 10
JPSmit why is this man happy? Spridgets 2
S Spitfire Nice Early Spit for Body Man to Examine Triumph 2
regularman I believe a blind man, might be able to see my... Spridgets 14
jlaird And the weather man says Spridgets 9
tony barnhill AW, MAN!! Spridgets 6
S Barn find, old man, two 67 Healeys, $1 ea, SOLD!!! Austin Healey 11
T Old Man needs help MG 11
T Who's a Betting Man? Triumph 18
Stewart Man do I feel dumb MG 0
T Exhaust Man. Gasket Triumph 14
Steve Isle of Man TT Video British Motorbikes 2
jlaird Morning guys, This old man Spridgets 32
AUSMHLY How to make a grown man cry Austin Healey 15
Simon TR4a Isle of Man TT- was it on Speed? British Motorbikes 1
Bret Who’s the man! err? I mean Mechanic! MG 16
tony barnhill Concrete Man Cometh... MG 6
TR4nut Poor Man's Emergency Bonnet Release - It works! Triumph 5
Patton One Man's [or Woman's] Taste or Pimp My Sprite Spridgets 8
Basil I met "the Man" Austin Healey 5
Kira A Great Wolseley Man: Peter Richardson Other British Cars 7
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
