Intermittent Stumble - Diagnosis?
Shinsen774
I have a stock '64 MGB except for petronix electronic ignition and an aftermarket fuel pump. It has run perfectly for the 2 1/2 years I've had it. The last week or so, though, when cruising at about 2500 RPM more of less, from time to time the engine will stumble and lose power, like it's not getting enough petrol. I can mash the accelerator and coax it to come back strong. It runs fine most of the time, this only happens from time to time. At idle, it usually runs fine, but a couple of times it has started to stall, and did stall once. Started
right back up normally. I have the glass fuel filter with the replaceable element. Took it apart and it is clean. We have ethanol here, but that's not a recent development.
What suggestions do y'all have for diagnosis and repair? Thanks in advance.
Jim
Mickey Richaud
Platinum
First thing that comes to mind are the carb dashpots. Checked 'em lately? Or, with the change in temperature, maybe the oil isn't doing its thing...?
PAUL161
Jim, Have you checked your fuel pump pressure? The pump might be intermittently dropping off. Then again it could be in the ignition where it seems most of these problems originate and we think their fuel related. I had a similar problem where the engine would not idle properly and thought it was a fuel problem, found out it was the distributor which had a wobbly shaft. Had it rebuilt by Advance Distributors, and it runs perfect. Best move I ever made. PJ
Shinsen774
Shinsen774
Carbs seem fine. Fuel pump seems fine. My theories are bad gas, vacuum advance leak, or coil going bad.
When I suck hard on the end of vacuum line, there is no movement in the distributor at all. Air comes through the line constantly. I checked the line itself, no leaks. Would the syptoms I'm experiencing be consistent with a leaky vacuum diaphragm? If so, what's the fix and how difficult is it to repair? What does the timing vernier do and how should it be set?
I found a brand new new coil in my parts bin that came with the car when I bought it. It's the right Moss PN for the car and tested OK. Put it on the car just to see. The problem still occurred, not as bad; inconclusive I guess. The old Lucas coil looks like someone hit it with a hammer a few times and might have been on the car for decades anyway.
Thanks for your insight.
Jim
PAUL161
The vacuum diaphragm assemblies are replaceable as a unit, but as far as I know, not repairable. Moss might sell them, I'm not sure. I would think that if you need to replace the vac unit, the whole distributor should be rebuilt. If the shaft has any wobble in it, you'll never get the engine to run right. Advance Distributors does an excellant job of rebuilding them. Jeff will even set it up to your specific driving needs.
Here,s the link; https://www.advanceddistributors.com/
Advanced Distributors: Distributor Repair at its Finest!
vping
I'd say he whips up a mean dizzy. He got a thumbs up from me.
Shinsen774
Shinsen774
New fuel pump cured the problem.....but in the process I also discovered that the vacumm advance on the distributor isn't holding a vacumm. Next project is getting that off and sending to Jeff Schlemmer for a rebuild.
Deleted member 8987
Distributor Doctor in England rebuilds vacuum units.
Had one done.
New innards, and once they cut it, looks like a new lip that covers both parts.
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
Griz Intermittent Misfire Austin Healey 33
S Intermittent operation of tachometer Austin Healey 9
Jim_Gruber Intermittent Horn Spridgets 2
T intermittent deflating tyre Austin Healey 6
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
doughairfield TR4/4A Intermittent vibration at 3000 RPM Triumph 2
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
AUSMHLY intermittent right blinker Austin Healey 14
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
Michael Oritt Intermittent short Austin Healey 14
R Intermittent starter Austin Healey 8
G Intermittent flasher [the TR that is] Triumph 8
nevets Intermittent sputtering Austin Healey 38
R BJ8 overdrive intermittent Austin Healey 11
roscoe Intermittent weirdness Austin Healey 20
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
athenssprite tach is intermittent Spridgets 5
healeyboz Intermittent problem finally fixed Spridgets 6
19_again intermittent power loss MG 0
Baz Intermittent miss? Spridgets 24
AUSMHLY Got intermittent wipers? Austin Healey 2
Dadandson Frustrating Intermittent Problem Spridgets 8
gsalt57tr3 Intermittent Start problem Triumph 1
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
M Intermittent Cooling Fans -'78 B MG 5
M Intermittent Wipers [the bad kind] MG 3
RobSelina Intermittent turn signals.... Spridgets 6
MGTF1250Dave Intermittent Electric Faults MG 9
M Intermittent starting problem Jaguar 1
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
Martinld123 A slight hesitation stumble at speed Austin Healey 13
Geo Hahn TR4/4A Stumble Off Idle When Hot Triumph 4
Geo Hahn TR4/4A Stumble Coming Off idle Triumph 9
Rob Glasgow Stumble on Acceleration Austin Healey 28
Nunyas heavy stumble at low RPMs - Catalytic Converter? MG 5
S TR6 72 tr6 stumble question Triumph 7
R TR2/3/3A TR3 stumble Triumph 9
C Stumble over 3500 rpm Triumph 12
C Stumble in acceleration... easy fix? Triumph 11
C TR6 Non-start diagnosis Triumph 9
Kleykamp TR2/3/3A 1961 TR3 turn indicator diagnosis? Triumph 4
TR4A_IRS Driveline Clunk Diagnosis Triumph 28
ObiRichKanobi Diagnosis Help Triumph 6
AN5Sprite Tunebug engine diagnosis, thoughts anyone? Spridgets 47
RAC68 How Good is your Diagnosis Austin Healey 6
jvandyke rear noise diagnosis Spridgets 24
