Intermittent Electric Faults
MGTF1250Dave
Aloha All,
My MG is being tempermental and the windshield wiper, turn signals are working only occasionally. It has been raining often lately so thehigh humidity and age (harness replaced about 20 to 25 years ago) may have degraded the electrical connections. I have correct voltage on both sides of the accessory circuit at the fuse box. If my diagnosis is correct, I guess the cure will be crawling under the dash and cleaning the bullets and connectors, cleaning all the ground connections and other connections. Does any one have other suggestions?
Safety Fast,
Dave
G
start cleaning and then protect them with a good electrical grease. different kinds can be bought at your local home stores, don't use much, it doesn't take alot. petroleum jelly can be used in a pinch. If you do this you won't have to do it again for a long time
G
Check the switches themselves first since you already checked the fuses. Thats usually the culprit in mine.
Bob
MGTF1250Dave
MGTF1250Dave
Thanks Chuck, It was about 25 years ago when I first made all the connections. You just can't get things that last anymore.
Safety Fast,
Dave
G
if you do find it to be the switches, there is an article on servicing them here (shamless website self promotion
tony barnhill
Great Pumpkin - R.I.P
2nd fuse from bottom....probably the gas guage also doesn't work sometimes also
MGTF1250Dave
MGTF1250Dave
Aloha All,
Well, I got everything working again when I turn the switch. No new parts needed. Since everything that was intermittent was powered through the accessory circuits (green Wires) I started there. I also discovered that the brake lights were not always working. I cleaned all the connections to the direction signal relay (also tied in to the brake light circuit) and the connections to the turn signal switch. I then cleaned all the bullets and connectors in the circuit. I think this is what solved the problem. I guess I need to add this procedure to the periodic maintenance schedule. Thanks for all the suggestions.
Safety Fast,
Dave
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
Griz Intermittent Misfire Austin Healey 33
S Intermittent operation of tachometer Austin Healey 9
Jim_Gruber Intermittent Horn Spridgets 2
T intermittent deflating tyre Austin Healey 6
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
doughairfield TR4/4A Intermittent vibration at 3000 RPM Triumph 2
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
AUSMHLY intermittent right blinker Austin Healey 14
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
Michael Oritt Intermittent short Austin Healey 14
R Intermittent starter Austin Healey 8
G Intermittent flasher [the TR that is] Triumph 8
nevets Intermittent sputtering Austin Healey 38
Shinsen774 Intermittent Stumble - Diagnosis? MG 7
R BJ8 overdrive intermittent Austin Healey 11
roscoe Intermittent weirdness Austin Healey 20
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
athenssprite tach is intermittent Spridgets 5
healeyboz Intermittent problem finally fixed Spridgets 6
19_again intermittent power loss MG 0
Baz Intermittent miss? Spridgets 24
AUSMHLY Got intermittent wipers? Austin Healey 2
Dadandson Frustrating Intermittent Problem Spridgets 8
gsalt57tr3 Intermittent Start problem Triumph 1
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
M Intermittent Cooling Fans -'78 B MG 5
M Intermittent Wipers [the bad kind] MG 3
RobSelina Intermittent turn signals.... Spridgets 6
M Intermittent starting problem Jaguar 1
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
R Rewind electric motor Restoration & Tools 3
JPSmit Electric Midget Spridgets 1
M TR6 Electric Powered Rack & Pinion. Triumph 4
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A An Electric TR3 ?? Triumph 3
Lin Electric Relay Placement Austin Healey 11
nevets interesting article about converting classic cars to electric power Austin Healey 7
FlyingCat Spitfire Electric Radiator Fan Triumph 10
M The electric E Jaguar 1
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
