TR2/3/3A TR3A Intermittent Pulling When Braking
Tugboat
Folks,
I am in the midst of re-falling in love with my 1959 TR3A now that the children have gotten older. Have recently worked through a number of issues (overdrive set-up, windshield installation, valve timing, pertronix installation, etc.) and am just now getting a chance to get out and drive on the weekends ("Butt cold" by Northern California standards, i.e. in the high 20s, but pretty wimpy to most). I am having a curious problem with braking. At speed the car will pull sharply to the right. I don't notice it when going slowly but at speed it can be very worrying. My first thought was that the driver's side front brake (the left) was not working but when up on jackstands all brakes appeared to engage, i.e. one of the kids would stand on the brake and I could not move any of the tires. I do not think it is the fact that I recently moved to silicone brake fluid as the symptoms were the same before and after. The system has been well bled. Any suggestions as to what I should look at next?
Thanks Much,
Mike
TR3driver
Great Pumpkin - R.I.P
FWIW, I had a similar symptom many years ago that proved to be caused by the lower rear pivot for the RH suspension being broken away from the remainder of the frame. Apparently the rod connecting it to the front lower pivot was enough to keep it in place during normal driving, but under hard braking it would deflect and allow the pivot to move, which would effectively turn the wheel to the left.
Tugboat
Tugboat
Hmmm, I will check that first thing tomorrow morning. Thank You.
hondo402000
I had an issue on my TR6 pulling to the left, the right front brake pads were saturated with brake fluid because of a leaking caliper, so the front left was braking and the front right was not causing it to pull to the left another thig you can check for
Hondo
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 0
Hamish Racing TR2/3/3A TR3a track fun in uk Triumph 2
F TR2/3/3A TR3A tub assembly Triumph 44
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 1
D TR2/3/3A TR3A electrical issues Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
B TR2/3/3A TR3a steering box rebuild Triumph 19
BritBob TR2/3/3A Part restored TR3A in Oregon Triumph 0
Hamish Racing General TR UK SPRINT RACE in my TR3a Triumph 5
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 6
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
G For Sale: Triumph TR2, TR3, TR3A, TR3B Factory Steel Hardtop, New Rear window, Partial Bracket Set Triumph Classifieds 2
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
Donald1107 59 TR3A Fuel Pump Triumph 48
D TR2/3/3A 1961 Triumph TR3a Triumph 17
D For sale. TR3A Bellcrank Pivot and lever. Triumph Classifieds 0
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
60TR3A TR2/3/3A How To Jack Up a TR3A Triumph 14
Hamish Racing TR2/3/3A Fast Road TR3a on figure of 8 sprint track - UK Triumph 10
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
71TR6 TR2/3/3A TR3A Wing to Apron Mismatch Triumph 9
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
S Price check on TR3A valve cover Triumph Classifieds 0
G 1962 TR3A inner plate # Triumph 8
G 1960 TR3A for sale $9,999 or best offer! Triumph Classifieds 3
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
71TR6 For Sale TR3A Roll Bar for sale Triumph Classifieds 1
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
S Wanted Wanted - TR3A Horns Triumph Classifieds 2
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
K For Sale TR3A Steering wheel Triumph Classifieds 4
A TR2/3/3A A rigged TR3a oil filter housing Triumph 8
T For Sale Tr3a 1961 Triumph Classifieds 0
S TR2/3/3A Need New Battery for TR3A Triumph 7
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
D Wanted TR3A starting handle Triumph Classifieds 0
T TR2/3/3A TR3A Door Handle Triumph 3
W TR2/3/3A TR3A Movie Sighting Triumph 8
D TR2/3/3A TR3A Crank Dog Triumph 2
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
J TR2/3/3A TR3A gas tank repair Triumph 4
