TR4/4A Intermittent vibration at 3000 RPM
doughairfield
Good Morning,
I've got a bit of a conundrum. I've got this irregular vibration which appears to be somewhere in the driveline on my 1964 TR4. The vibration only starts when you pass 3000 RPM under power and it’s irregular. I think I can feel the vibration most in the gear shift lever but I can kinda feel it through the floorboards of the car, but not in the pedals or steering wheel. Push the clutch in or go back under 3000 RPM and the vibration goes away. I’m thinking it’s some bearing somewhere that is bad but I don’t know how else to test at this point. I tried sustaining 3400 RPM in 2nd or 3rd gear but I’m having a hard time finding a stretch of road I can do that on. I don’t think I feel the vibration in any other gear but 4th but I’m still testing. I did have a bad transmission mount and replaced that a few months ago. I also had a U-Joint on the transmission side of the driveshaft that was pretty rough on one axis which I thought was the problem and I replaced that last week, vibration is still there.
Since the transmission mount AND the drive shaft seem to be in good working order now. Any ideas on what could be causing that vibration?
Geo Hahn
I have never had to have the propshaft (driveshaft) balanced on mine -- but that is one thing I'd look into if I couldn't track down a driveline vibration.
doughairfield
doughairfield
That's a really good point about the driveshaft. Now that I think about the vibration some more, it's really more like a resonance through out the car which I think is a symptom of a driveshaft out of balance. Shouldn't be too big a deal to get the DS checked out. Thanks for getting me thinking.
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Popeye TR4/4A Transmission noise - intermittent Triumph 22
B Intermittent Loss of Electric Power Austin Healey 18
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
Griz Intermittent Misfire Austin Healey 33
S Intermittent operation of tachometer Austin Healey 9
Jim_Gruber Intermittent Horn Spridgets 2
T intermittent deflating tyre Austin Healey 6
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
AUSMHLY intermittent right blinker Austin Healey 14
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
Michael Oritt Intermittent short Austin Healey 14
R Intermittent starter Austin Healey 8
G Intermittent flasher [the TR that is] Triumph 8
nevets Intermittent sputtering Austin Healey 38
Shinsen774 Intermittent Stumble - Diagnosis? MG 7
R BJ8 overdrive intermittent Austin Healey 11
roscoe Intermittent weirdness Austin Healey 20
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
athenssprite tach is intermittent Spridgets 5
healeyboz Intermittent problem finally fixed Spridgets 6
19_again intermittent power loss MG 0
Baz Intermittent miss? Spridgets 24
AUSMHLY Got intermittent wipers? Austin Healey 2
Dadandson Frustrating Intermittent Problem Spridgets 8
gsalt57tr3 Intermittent Start problem Triumph 1
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
M Intermittent Cooling Fans -'78 B MG 5
M Intermittent Wipers [the bad kind] MG 3
RobSelina Intermittent turn signals.... Spridgets 6
MGTF1250Dave Intermittent Electric Faults MG 9
M Intermittent starting problem Jaguar 1
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
R BJ7 heater blower vibration Austin Healey 11
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
mcmillal TR4/4A Front End Vibration Triumph 9
PAUL161 T-Series Scuttle Shake/Vibration MG 6
B Drive line vibration Austin Healey 16
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
bugedd Engine Vibration Spridgets 3
T TR2/3/3A How much vibration in a Triumph 4 cylinder engine? Triumph 12
T vibration Jaguar 9
JodyFKerr Wedge Triumph TR8 Vibration Damper Triumph 21
bighealeysource Feel vibration when depressing clutch pedal on BN2 Austin Healey 4
Q TR2/3/3A Shaking/Vibration On TR3A!!! Triumph 15
B instructions to install vibration dampener Austin Healey 2
