Intermittent Cooling Fans -'78 B
Midgey
Member
Hello experts. Cooling fans decided not to run for several days on '78 MGB, just as our high desert temperatures are beginning to climb into the 70's. Then, last evening on the drive home, voila! There they were, alive and frisky again? Likeliest culprit? Would it be relay, sympathetic pains for MGR demise, or something else?
ROADSTR6
Try replacing that thermastatic switch at the top of your radiator. My '78 did the same thing (before I sold it). Beware, I had to get two switches because the first one was faulty right out of the box. Also, get a new rubber grommet to ensure you don't have any leaks. Piece of cake!
MGTF1250Dave
Aloha Midgey,
A quick test of the thermostatic switch is to by pass it by removing the two wires from it and connecting them together. Turn on the ignition and see if the fans run. Another possibility is a faulty or poor ground connection from the fan motors.
Safety Fast,
Dave
RF Thom
Midgey
The fans run direct through the sensor in the radiator, of which the points are not strong enough to carry the current drag of the fan motors, especially if you have two [2] fans. Utilize a relay and use the sensor in the radiator to trigger the relay. After replacing the sensor twice, I knew something different was needed. I took apart the sensor and discovered the internal contacts burnt to a crisp. I installed the relay and six [6] summers of driving without a problem. Last year I modified the circuit and tied it also into the overdrive circuit on the gear lever switch : 1st, 2nd & neutral - fans on, 3rd, 4th & overdrive on - fans off. Helps in city driving and I don't have to keep an constant eye on the temp gauge.
Regards, Bob
M
Midgey
Member
Thanks to all who weighed in on this. It was the radiator switch. Got a Lucas switch from the local MG specialists, which they insisted on pairing with a Jaguar heavy-duty gromet because the gromet which comes with the switch is well known to be inadequate. Anyway, smooth and easy replacement even for a newby car guy. Got it, ran it up to temperature and presto! The sound of those lovely dual fans!
Midgey
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
Griz Intermittent Misfire Austin Healey 33
S Intermittent operation of tachometer Austin Healey 9
Jim_Gruber Intermittent Horn Spridgets 2
T intermittent deflating tyre Austin Healey 6
Crankshaft TR2/3/3A Intermittent ignition switch problem Triumph 9
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
doughairfield TR4/4A Intermittent vibration at 3000 RPM Triumph 2
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
AUSMHLY intermittent right blinker Austin Healey 14
Tugboat TR2/3/3A TR3A Intermittent Pulling When Braking Triumph 5
Michael Oritt Intermittent short Austin Healey 14
R Intermittent starter Austin Healey 8
G Intermittent flasher [the TR that is] Triumph 8
nevets Intermittent sputtering Austin Healey 38
Shinsen774 Intermittent Stumble - Diagnosis? MG 7
R BJ8 overdrive intermittent Austin Healey 11
roscoe Intermittent weirdness Austin Healey 20
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
athenssprite tach is intermittent Spridgets 5
healeyboz Intermittent problem finally fixed Spridgets 6
19_again intermittent power loss MG 0
Baz Intermittent miss? Spridgets 24
AUSMHLY Got intermittent wipers? Austin Healey 2
Dadandson Frustrating Intermittent Problem Spridgets 8
gsalt57tr3 Intermittent Start problem Triumph 1
MadRiver Slightly OT -- Intermittent short with my Tiger Triumph 14
M Intermittent Wipers [the bad kind] MG 3
RobSelina Intermittent turn signals.... Spridgets 6
MGTF1250Dave Intermittent Electric Faults MG 9
M Intermittent starting problem Jaguar 1
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
steveg TR6 Cooling system filling Triumph 7
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
Drone Dog BT7 air ducting / cooling Austin Healey 20
Drone Dog Trying to understand my cooling system Austin Healey 29
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
F Cooling Austin Healey 3
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
7 stupid plastic cooling system parts Other Cars 2
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
R TR2/3/3A Non Triumph cooling question Triumph 8
apbos Parade Cooling Help Spridgets 12
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
D 2.4L internal cooling passages? Jaguar 4
J Another what cooling fan is this question? Austin Healey 47
H Denis Welch cooling fan arrived today Austin Healey 2
steveg Definitive results of tests on factors influencing cooling Austin Healey 46
