Battery for my 64 Etype coupe 3.8
chasers03
I want a correct size battery which has no acid, ie. dry/gel cel for my 64 E-type 3.8 coupe.
Does anyone know the size of the original battery and of a source for such a non-acid battery??
Steve
rotoflex
You'll have to size it elsewhere, but for a manufacturer, I will personally recommend the Odyssey dry cell line.
https://www.odysseybatteries.com/
I had been reading messages from autocrossers who'd replaced their lead/acid batteries with lighter Odyssey dry cells, & who'd found they were fine for daily driver use.
I got an Odyssey PC680MJT (has automotive terminals) which is about 40% of the size of the OEM battery for my Neon, & it's been great. And it weighs about as much as a book, as opposed to as much as a car battery. Real Soon Now, I am going to get one for the GT6 (probably larger capacity, as the GT6 has 2 more cylinders & sometimes needs to spin some more to start than the FI Neon).
GregJ
Gell cell battery is the way to go. I have been using Optima batteries in all of my collector cars with great success. They are the same size as the lead/acid originals so you do not have to deal with changeing and figuring out new holddowns for the battery that is a different size. I use my cars sporatically so the battery is left to run down and is recharged on occasion if at all. Gell cells take that kind of abuse very well. I would get a "deep cycle Optima gell cell." I have used them in my:
enclosed trailer
D-Type Jag
C-Type Jag
67 XKE OTS Jag
64 XKE lightweight Jag
Austin Healey 100S
All do very well and the battery lasts for years.
GregJ
C
chasers03
Thank you however I am confused in that the Optima web site says their battery is not a Gel Cel as noted here in a
FAQ 11. What is a gel cell battery? How does the OPTIMA battery compare?
A gel battery is typically a modification of a conventional lead-acid automotive or marine battery. A gelling agent is added to the electrolyte to reduce movement inside the battery case. OPTIMA Deep Cycle batteries are able to deliver and receive higher amperages than gel cell batteries, due to the much higher internal resistance of gel batteries. Most gel batteries cannot handle engine starting duties, but OPTIMA Deep Cycle batteries excel in such applications.
Thanks from Steve Chase
BIBBER
Steve...my philosphy is to go with a modern dependable high cranking amps battery....best you can afford....stick a label on it and/or paint it to look close to opriginal but if you're not showing and want to drive it....you'll be glad you can count on the battery!!!!
Keoke
Bugeye58 said:
Aren't Optima batteries spiral wound "Glass Mat" types?
Jeff
Yep they sure are. However, there are Gel Cells that can be used to replace the standard lead acid car battery. Similarly they are not light or inexpensive. OTOH both batteries are of the Glass Matt Type.--Fwiw--Keoke
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
RAC68 Battery Powerline Protection Austin Healey 40
