1500 battery cable colors
sparkydave
I'm curious, what colors are the stock battery cables supposed to be on a 1500? Mine are "backward" from the modern convention; red is negative and black is positive even though they were all negative ground. Previous owner insists he never had them replaced, so as far as I know that's how it was originally. I'd swap them but the ring terminals are different sizes. Only thing that bugs me is when I get the battery tested at Autozone, I have to assure them that red is really black and black is really red.
glemon
Tell you buddies at AutoZone about the + and - symbols on the battery, I know sometimes hard to see, but still. British cars are quirky, but I don't imagine BL was unconventional with their battery cable colors in the 70s.
F Spitfire Battery Size for Spitfire 1500 and TR6 Triumph 3
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 5
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
G For Sale TR2 TR3 TR3A TR3B Unrestored Hardtop with Window, New Hardware kit and Seals $1500 Triumph Classifieds 2
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
Rut 1500 gas pedal for sale Spridgets 7
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
Editor_Reid T-Series Original Price in US Dollars for an MG TF 1500 MG 4
B 1500 Exhaust Spridgets 10
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
T Spitfire Oil Filter 1500 Triumph 1
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
R reason for it said 1500 has cooling [run to hot] problems? Spridgets 18
J 1500 mg midget fuel issue Spridgets 2
J T-Series 1955 MG TF 1500 Transmission MG 2
C 1500 gt pre cross flow Other British Cars 4
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
