TR6 Fixing the intake manifold
steveg
Is there anyone out there who can shape the intake manifold better? Or is there any info on doing it yourself.
This looks like it could use some work ('74 TR6):
CJD
A die grinder with a carbide burr makes very quick work of matching ports. You can finish up with a flapper wheel or sanding roll. Most are available from welding or nut and bolt supplies. The die grinder can be found at Harbor Freight or Northern Tool. Of course you'll need an air compressor.
sp53
I like rotary files and dermal stones for smoothing. The rotary files in a cordless drill because the files are aggressive and the stones in a die grinder for the high RPM and smoothness.
steve
steveg
steveg
CJD
I've done the dremel and drill routines. They will work, but will take at least 30 minutes time for the same amount of metal removal as just 1 minute with an air powered die grinder and a carbide burr.
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Got_All_4 TR6 Is this head toast or worth fixing Triumph 3
S TR4/4A Fixing dash support Triumph 11
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
M BJ7 back panel fixing method Austin Healey 5
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
Jeepster Seat belt fixing Austin Healey 4
P BJ8 wing and panel fixing help? Austin Healey 3
Jeepster Front wing flash fixing holes Austin Healey 5
JamesWilson Fixing Fiberglass Flaws?? Restoration & Tools 9
T ideas on fixing - one carb keeps "rusting" Triumph 4
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
T Tips for locating/fixing foam rings under gas tank Triumph 4
T Ideas on fixing this? Triumph 19
regularman Found one problem while fixing another Spridgets 9
B Fixing crack in rubber bumper MG 1
bcliff Fixing a bad spot in the paint MG 3
germanmichel Fixing outer tube in steering box Austin Healey 11
G I my engine fixing to blow........................ Triumph 9
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
roscoe I'm fixing my overdrive with a saws-all Austin Healey 10
jhorton3 Fixing Things Spridgets 27
drooartz Leaking hubs, parts for fixing Spridgets 11
T Fixing Rust Triumph 16
bluemiata90 Fixing turn signals at head Triumph 3
69MGC Any tips for fixing a bent boot lid MG 7
cjm lightened flywheel,best fixing? Triumph 3
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
S Fixing Dime sized chip Triumph 3
M Wedge tr7 turn signal switch fixing? Triumph 1
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
B Will fixing Healey Shake negatively affect Resale? Austin Healey 6
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Intake header crossover passage..... Triumph 4
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
shadowfever MGB MGB intake wanted MG 2
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
