Leaking hubs, parts for fixing
drooartz
I've got a leak in one of my rear hubs, so I'm assuming I'm looking for something like this:
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29295
Moss: #125-830
(the kit includes 3, 35, 36, 37, 38)
I'd probably get extra 35 and 37 just in case.
This looks like it's got the necessary gaskets and bits to renew the hubs. Not that I know how to do that, but there's not time like the present. I'm putting a big order in for Tony tomorrow
drooartz
drooartz
I've got a local guy who should be able to make one up for me, I hope. I'll run those drawings I made by you again, and make sure I've got the measurements right.
Sarastro
I just went through this. I used a simple hub puller from Harbor Freight and (get ready....) bought a set of 3/4" drive sockets for that huge nut that holds the hub on. I found the other sockets useful for all kinds of things too, and, given that the HF set wasn't terribly expensive, it all was worthwhile. Unless the bearings are loose or otherwise questionable, I don't think you need the whole kit--just the seals, which are a lot cheaper. Also, buying one or two extra seals isn't a bad idea--it's not difficult to mash a seal while installing it, and it's good to have a spare. Also, if you have extras, you'll probably use them someday. (I know, confidence!)
You will need to have something to cover the hole in the axle housing when you pull the hub--a circular piece of any kind of metal will do, as long as it's the right size.
Not really a difficult job--the only slightly difficult part is working with all those press-fit bearings.
drooartz
drooartz
Thanks for the clarification, Jeff.
I've got the socket already, from when I stripped the Midget out this past winter. I'll have plenty of questions once I get ready to tackle this job. I know how to pull the hub out, but really don't have much of an idea of how to put it back together.
drooartz
drooartz
I've always loved that line, especially when the removal steps aren't entirely clear in my brain. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
drooartz
drooartz
I decided to go with the kit, since I don't know the condition of the bearings. I'm also going to get a few extra seals/o-rings/gaskets, just in case. In the context of the larger order I'm making for Tony, this is just a small percent of the cost, so I'd rather err on the side of caution and have a few spares on hand.
Yup, I have spare manifold gaskets, rocker cover gaskets, etc. They would be very handy if I could find them when I need them, but instead I only see them when they are in my way as I look for other stuff.
Maccers Leaking rear hubs on BN4 Austin Healey 6
R TR2/3/3A Leaking O.D. section of Transmission Triumph 17
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
Drone Dog BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
D Overdrive Leaking Oil Austin Healey 4
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
PatGalvin TR2/3/3A Leaking SUs. Advice badly needed Triumph 15
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Michael Oritt Leaking oil pan Racing 8
T TR6 leaking carb TR6 Triumph 17
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Rob Glasgow Leaking tapered plug on head Austin Healey 8
Scotsman TR2/3/3A leaking front engine plate Triumph 4
bigbadbluetr6 TR6 Carb leaking Triumph 12
M TR2/3/3A Head gasket leaking in two places Triumph 13
Boggsy64 MGB Stormberg leaking like a sieve MG 4
K TR2/3/3A Leaking Gearbox drain plug....... Triumph 6
F More oil leaking...rear seal? Triumph 3
S Carb Leaking Gas Austin Healey 12
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
D Fuel leaking from carbon canister Triumph 6
D Leaking Top Austin Healey 6
AUSMHLY BJ8 replacement front Lever Shocks keeps leaking Austin Healey 40
D Leaking fuel pump connections Triumph 32
