Fixing Rust
T
Tinster
I'm about to get into some rust stabilization
prior to installing Crypty's new wool carpet
interior. This topic is appearing now in several
threads. After Bill nightmare with the red lead,
I started doing some research on rust and so did
some other folks here.
The product "Rust Bullet" was mentioned many times
in my own research and also here in the forum. This
appears to be a very viable rust stabilzation product.
https://www.rustbullet.com/index.htm
They do not ship to Puerto Rico "because PR is not part
of the United States". So I called them and spoke to a
knowledgeable tech guy named Frank Frank@rustbullet.com
They have a dealer about ten miles from my house. Frank
said to tell everyone on the formus to e-mail him with any
questions.
Frank said the standard formula mix is just fine for general
use where it will not be seen. He said the automotive
formula is a thinner mix compounded so it can be spray gun
applied to outer body panels.
I'll try to pick some up next week, try it out, and report back. I have some mild rust on the rails the tranny cover sits upon. Need to correct it before the carper install.
Lets hope for positive results and no nightmares like poor
Doc Bill.
dale.
jackag91
I used the eastwood rust encapsulator. I have been really happy with it. The one caveat is I haven't had it on the car the yet, so I can't speak to the durability but it seems like it will hold up. At least it held up to the finger nail test and when I dropped it.
linky to site
jackag91
here is a link to a jeep board that discusses rust bullet and has a dealer that is answering a lot of questions.
He has a great idea on how to keep a gallon can good and usable for a long time.
T
Tinster
WOW!! Impressive Q/A forum
Poor Doc Bill could saved a bunch of grey hairs
and hours of his time if he had know about Rust Bullet.
I am glad I took the time to research a different product
than Bill's.
d
T
Tinster
Td- I'll try to take a photo over the weekend.
Floor pan is a gaping open hole. The side rails
that surround the tranny have only a small amount
of rust.
I intend to sand out the rust, Pos aicid it use
Rust Bullet over the whole rail.
Floor pan will require major removal, restoration
effort. /bcforum/images/%%GRAEMLIN_URL%%/nopity.gif
d
kodanja
Fred Flintstone brakes! /bcforum/images/%%GRAEMLIN_URL%%/lol.gif
Brosky
Dale, Isn't that an old picture? I thought that you fixed that way back when? I'm a little behind on the car status, but I thought that you posted some really nice pics of bonded in panels down there.
Oh yeah, you talked to a guy named "Frank Frank" in tech support?? What happened, was John John busy when you called in?
kodanja
marbel floor would be going with the Flinstone's theme right?
T
Tinster
I could design, cut and install a fabulous marble
floor in far less time than it will take to install
new steel.
Paul, old photo but still exists in Crypty. I had
to install a temporary alum floor to support my feet
while trying to get Crypty operational.
Yes, I used epoxy ReziWeld and tek screws and painted
it nice. But it was a temp. fix. I ain't no DPO Pedro.
d
rotoflex
TR6BILL said:
Dale, have you considered a marble floor. That would be unique.
I believe tradition demands the installation of a stolen highway speed limit sign.
T
TRDejaVu
I have used Eastwood Rust Converter followed by Rust Encapsulator (for the inside of fenders and hidden areas etc.). Pleased so far, but time will tell as to how well they hold up over the years.
Joe_Pinehill
Dale, after you cut out the area that needs to go, you might wire brush, then use Phosphoric Acid to eliminate all the rust before coating. You can buy it by the gallon in Home Depot or Paint Stores, (Benjamin Moore sells it, and Home Depot has a different label. Then wire brush again, and you should have a rust free weld zone. The phosphoric acid will convert all the iron oxide to iron phosphate, and not harm the parent steel/iron.
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
steveg TR6 Fixing the intake manifold Triumph 8
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Got_All_4 TR6 Is this head toast or worth fixing Triumph 3
S TR4/4A Fixing dash support Triumph 11
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
M BJ7 back panel fixing method Austin Healey 5
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
Jeepster Seat belt fixing Austin Healey 4
P BJ8 wing and panel fixing help? Austin Healey 3
Jeepster Front wing flash fixing holes Austin Healey 5
JamesWilson Fixing Fiberglass Flaws?? Restoration & Tools 9
T ideas on fixing - one carb keeps "rusting" Triumph 4
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
T Tips for locating/fixing foam rings under gas tank Triumph 4
T Ideas on fixing this? Triumph 19
regularman Found one problem while fixing another Spridgets 9
B Fixing crack in rubber bumper MG 1
bcliff Fixing a bad spot in the paint MG 3
germanmichel Fixing outer tube in steering box Austin Healey 11
G I my engine fixing to blow........................ Triumph 9
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
roscoe I'm fixing my overdrive with a saws-all Austin Healey 10
jhorton3 Fixing Things Spridgets 27
drooartz Leaking hubs, parts for fixing Spridgets 11
bluemiata90 Fixing turn signals at head Triumph 3
69MGC Any tips for fixing a bent boot lid MG 7
cjm lightened flywheel,best fixing? Triumph 3
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
S Fixing Dime sized chip Triumph 3
M Wedge tr7 turn signal switch fixing? Triumph 1
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
B Will fixing Healey Shake negatively affect Resale? Austin Healey 6
5 BJ7 Boot Rust-Through Austin Healey 13
E Rustproofing and Rust Austin Healey 2
1 General Tech Rust Proofing Triumph 7
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
D TR6 Rust and hesitation 71 TR6 6 Triumph 9
D Removing the last rust from pitted steel Restoration & Tools 11
algot1901 My Prefect in her B-Day Suit and playing with rust-Flash! Other British Cars 19
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
SteveTheBrewer Spitfire More rust repair Triumph 1
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
R Rust in Block? Help needed! Austin Healey 6
F TR2/3/3A Rust under flanges Triumph 7
D MGB Stopping rust under patch panels MG 1
P BJ8 Frame Rust Options? Austin Healey 14
